Multiple NAT
Chin
Hi Guys,
Just wonder can i add a multiple NTP for failover?
Example, my router has 2 NTP reference ip , if ntp#1 show unsync, can it failover to ntp#2 for time sync?
Sajid Ali
Hi tppsupport,
I think you require NAT-Failover. If so, you may accomplish your task via route-map, but first of all share you requirement details so that I will assists you better.
Don't forget to rate helpfull posts.
Sajid Ali Pathan
