Multiple static nat port ranges to multiple inside hosts
M@rco
Hello there,
i would like to implement some special nat configuration to a Cisco ISR 4331.
I have one outside interface, in this example with the address 11.22.33.44 und an internal interface, lets say 192.168.1.0/24.
They are both in the same VRF. Using a VRF for these interfaces is mandetory.
interface gi0/0/0
description outside
ip add 11.22.33.44 255.255.255.252
vrf forwarding INET
ip nat outside
interface gi0/0/1
description inside
ip add 192.168.1.1 255.255.255.255
vrf forwarding INET
ip nat inside
vrf forwarding INET
Now, i wanto to implement some portforwariding like this:
192.168.1.10 should be reachable over the public ip adress an the ports 111 ,222, 333
192.168.1.20 should be reachable over the public ip adress an the ports 444, 555, 666
192.168.1.30 should be reachable over the public ip adress an the ports 777, 888, 999
i used to configure ip nat inside destination list <ACLwithPorts> pool <poolwithclientip>
but unfortenately this solution seems not to be vrf-aware.
i also tried to use route-maps, but i can´t use two lines with the same outside ip:
ip nat inside source static 192.168.1.10 11.22.33.44 vrf INET route-map <MapwithPorts> extendable
ip nat inside source static 192.168.1.20 11.22.33.44 vrf INET route-map <MapwithotherPorts> extandable
% 192.168.1.20 already mapped (192.168.1.10 -> 11.22.33.44)
Somebody has a good solution except that i use multiple static nat commands for each port/inside host?
Hello
Do you have your route-map in the vrf INET?
What do you access-list looks like?
What software are you running?
Example:
access-list 101 permit tcp host 192.168.1.10 any range 1111 2222
route-map PR permit 10
match ip address 101
set vrf INET
ip nat inside source static 192.168.1.10 11.22.33.44 vrf INET route-map PR extendable match-in-vrf
ip route vrf INET 0.0.0.0 0.0.0.0 GigabitEthernetx/x 11.22.33.4x
Kind Regards
Paul
