Multiple Subnet Table RV345
mwtompkins78
I have been working with RV325 and was able to add another subnet in the Multiple Subnet Table under Setup-> Network without creating a VLAN. Now we are upgrading to RV345 and I am unable to find where I can add another subnet for routing. Can someone point me to where this setting is now in the RV345.
Thank you!
10 Replies 10
balaji.bandi
Not sure is this correct, try system configuration --> IP address group
BB
I don't think the option is there on the RV345 anymore. You need to add a VLAN in order to add a new subnet (page 53 of the attached guide)...
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Administration/EN/b_RV340x_AG.pdf
mwtompkins78
The problem with that is I have to assign it to a port. With the RV325 I could just define a subnet and if a static with that subnet plugged into any port it would just route. Any thoughts on how I can get that functionality with the 345?
May this is what my understating, I am not a big user of RV3XX Router, but in RV325 when you add a subnet, that goes into default VLAN1 as secondary (i believe due to Limitation they might have added that feature since it can not go more than /24 prefix. in RV345 you can have your own prefix more than /24 (that is the reason i am guessing they have removed that option).
for better clarity you can reach out SMB TAC support.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
BB
mwtompkins78
Ok that makes sense, I will reach out to them, but until I have time to do that, Any idea how do I replicate that functionality with the RV345, by making a secondary subnet on VLAN1?
Thank you!
You can not have a secondary subnet here as i mentioned,  instead you can increase the prefix (this need to test, i go by technical details.)
example :
192.168.1.0/23 to cover 192.168.1.0/24 and 192.168.2.0/24
BB
mwtompkins78
That would work but what if I had 192.168.1.0/24 and 10.12.0.0/24. I use one of my routers as a setup station and I just add the location I am setting up to the subnet table in the RV325 so my example is a very common occurrence. If VLANs are the only way I can do that just would like to avoid the extra steps and have the simplicity of just add and go.
I can clearly understand the requirement, even i am in your position i expect the same, but if the product has limitation (not anyone can help, hence TAC case)
by the way, when you add 2 subnets (the different one you mentioned ?)  what is the Gateway you configure on the end device?
example: 192.168.1.0/24 VLAN 1 (SVI VLAN 1 configured 192.168.1.1)
if the device in 10.12.0.0/24, what is the gateway here ?
just asking is there an alternative method we can suggest.
BB
mwtompkins78
typically the gateway is 10.12.0.1 and 192.168.1.1 respectively.  I really appreciate the help!
Ok so it automatically adding secondary IP to  Interface (the feature is missing in  new model) - good feedback thank you.
BB
