Multiple vlans on Fastethernet link
kunal-united
Hi I have a cisco switch port 1 connected to router on fastethernet 0/2.
Now I have multiple vlans being carried to Fastethernet 0/2.
On the switch I make a trunk port to the router.
And on the router what should I do??
int fast 0/2
no ip address
? ...do I have to put encapsulation dot1q
then create subinterfaces
int fast 0/2.462
vlan-id dot1q 462
ankbhasi
Hi Kunal,
On the router you have to create subinterfaces for the number of vlans you want it work for.
Something like this
interface fa0/2.1
encapsulation dot1q
ip address
interface fa0/2.2
encapsulation dot1q
ip address
Also encapsulation command support depends on the router and IOS you are running. You need to have IP PLUS feature atleast to support the encapsulation command.
Ankur
mchoo2005
In addition to the previous post, most platforms require the subinterface number to match with the VLAN number.
E.g. for VLAN 2, the subinterface would be fa0/2.2. For VLAN 10, fa0/2.10, etc. etc.
Ahmede
You will need to do that..
interface fast 2/0.462
encapsulation dot1q 461
