03-27-2014 10:32 AM - edited 03-04-2019 10:40 PM
I have 2 switches, one is a Cisco 3750 and the other is a Cisco 2950.
I can ping the interface from each switch on each PC, and vice versa, but I cannot ping across the trunk port from PC to the other VLAN. I am definetly a noob at this so any one that can spread some clear instructions on how to do this would be greatly appreciated.
Config for Cisco 3750:
Building configuration...
Current configuration : 2451 bytes
version 12.2
no service pad
hostname 3750Cisco
boot-start-marker
boot-end-marker
enable password XXXXXXX
no aaa new-model
switch 1 provision ws-c3750g-48ts
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
switchport access vlan 49
switchport mode access
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
interface Vlan49
ip address 10.0.0.1 255.255.255.252
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Config file for 2950:
Current configuration : 1348 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 91
switchport trunk allowed vlan 1-99
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport access vlan 24
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan24
ip address 216.68.91.225 255.255.255.224
no ip route-cache
ip default-gateway 216.68.91.226
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
03-27-2014 11:05 AM
I have three observations I made on your configs...
1. You are not running a routing protocol
2. You do not have static routes pointing where you want the traffic to go.
3. You need to enable ip routing on the switches [with command ip routing]
Either configure a routing protocol or static routes. Remember you will need a static router on each switch to point to the other....
something like 0.0.0.0 0.0.0.0 10.1.1.1 [being the ip of the other switch]
HTH...
03-27-2014 12:14 PM
1. Can you clarify this?
2. Again not clear
3. I did do this on both switches.
Thanks for answering but still I am just as confused.
03-27-2014 12:18 PM
Am I safe to assume that maybe the 2950 does not support routing?
