Multiple VRF for Cisco 892
nihit-tandon
Level 2
Level 2
  Hi All,
Need advice  i am proposing cisco 892 series router for multi VRF Configurations-MPLS. Is there any challenge you foresee in this  architecture.
PE-CE ---> BGP
If possible pls share brief  sample config.
Hello Nihit,
I have provided a configuration example of a Multi VRF CE not of the PE node.
>> So you can use C892 only as multi VRF CE ( VRF lite).
If you want to use the C892 as a simple CE node the configuration is simpler without using VRFs
Hope to help
Giuseppe
Giuseppe Larosa
Hello Nihit,
according to the following document C892 supports up to 5 VRFs with Advanced IP services feature set, but it does not support MPLS.
see
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6557/prod_white_paper0900aecd8051fbdc.html
So you can use C892 only as multi VRF CE ( VRF lite). This means that each VRF requires a distinct logical link to PE router to achieve connectivity.
These logical links can be implemented with Vlan based subinterfaces
If you want to use eBGP as PE-CE routing protocol you will need an eBGP session for each defined VRF using the logical PE-CE link.
ip vrf BLUE
rd 100:1
route-target import 100:10
route-target export 100:10
ip vrf RED
rd 100:2
route-target import 100:20
route-target export 100:20
interface fas0/1
no ip address
interface fas0/1.10
enc dot1q 10
desc subnet link BLUE VRF
ip vrf forwarding BLUE
ip address 10.100.101.1 255.255.255.0
interface fas0/1.20
enc dot1q 20
desc subnet link RED VRF
ip vrf forwarding RED
ip address 10.200.201.1 255.255.255.0
interface fas0/0
no ip address
interface fas0/0.10
enc dot1q 10
desc PE-CE link BLUE VRF
ip address 10.100.100.2 255.255.255.252
interface fas0/0.20
enc dot1q 20
desc PE-CE link RED VRF
ip address 10.200.200.2 255.255.255.252
router bgp 65001
address-family ipv4 vrf BLUE
no sync
redistribute connected
neighbor 10.100.100.1 remote-as 65000
address-family ipv4 vrf RED
no sync
neighbor 10.200.200.1 remote-as 65000
the first eBGP session advertises subnet 10.100.101.0/24 to PE device, the second eBGP session advertises 10.200.201.0/24.
See a full example in the following document
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/vrf.html
Hope to help
Giuseppe
Thanks Giuseppe for your response,
I guess the above mentioned configs are of PE router. I am looking for CE configs.
The 892 router will be deployed as CE so nt sure why MPLS support is required apart from QoS the Lables/RD/RT will be assigned  from the PE router.
Hello Nihit,
Hope to help
Giuseppe
Thanks , Let me check
