Multiple VRFs on LAN
coder2501
Dear all,
I am fairly new to this forum, and would like to introduce myself first. My name is Michael and I am a network consultant.
One of our client has a challenge with local LAN separation, the scenario is like following:
  • Hub and spoke IPSEC/GRE
  • Spokes need complete separation of 3 x LAN subnets (Voice, Data, Video) from each other.
  • The traffic between these subnets should only be allowed/filtered by the Hub router.
What I wanted to propose is on the Spokes: 3 x VRF lite
So far so good, but how am I going to deal with uplink/WAN. Would that mean, that I would need three Tunnels as well?
Ideal would be 3 VRFs for LAN and One single Uplink to the Hub where all VRFs are send over. Any idea how to achieve this?
Best
Mike
Jon Marshall
Mike
I don't think this is possible or at least I don't know of a way to do it because the hub device tunnel interface would be in the global routing table or one of the VRFs which wouldn't work.
If you have 3 VRFs at each spoke and you want to maintain that segregation at the hub then you need three tunnels at the hub ie. effectively you have 3 DMPVN clouds, one per VRF.
Just to clarify, when you say isolation at the spokes you mean that the 3 vlans cannot communicate with each other within each spoke site.
But the data vlan at one spoke site can communicate with the data vlan at another spoke site for example.
Is that correct ?
Edit - forgot to say, welcome to the forums :-)
Jon
Hi Jon,
thx for your comments:
<Just to clarify, when you say isolation at the spokes you mean that the 3 vlans cannot communicate with each other within each spoke site.
But the data vlan at one spoke site can communicate with the data vlan at another spoke site for example.>
Yes, data on spoke (A) can talk to data on spoke (B). And within spoke (A) none of the VRF can talk to each other.
Hope that clarifies the picture
cheers
Mike
