High CPU in CISCO 3925
vamsi harish
Dear All,
Recently we are facing high CPU at our MPLS router. I've observed that, even though the total processes cpu utilization is high but there are hardly 5 processes above 0.00% and cumulatively contributing less than 2%. We want to know what is actually causing the cpu to reach 100% and resolve this issue. I'm attaching the logs for your reference. I need your help to find the root cause and resolve the issue.
Vamsi Harish.T.
vamsiharish@gmail.com
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It appears almost all your CPU is in the interrupt process, i.e. normal packet forwarding.
It also appears you're moving over 100 Mbps of traffic.
Cisco recommends the 3925 for up to 100 Mbps of WAN (i.e. duplex) traffic.
So, your usage doesn't appear very abnormal.
