Multiple Wan - best practice
locus2007
Hallo,
I got problem with my provider where ADSL line that was 16Mbit now have so bad parameters noise margin about 6db, 12Mbit - 9db and 8Mbit - 16db.
So use full is 8Mbit now and I need better connection because many Lan users and some VPN remote users. So 8Mbit / 512 not so good as before 16Mbit / 800.
Device is 1802 one ADSL and one FE0 wan port.
So my ideal is have two 8Mbit / 512 ADSL connections and now what, as I understand Loadbalancing per dest is good for that users are balanced to two connection on cost of destination, how it is when it is from same ISP?
The download speed will be maximal 8Mbit or will be used in same time both connection so can by twice?
Because here is Easy VPN server, that will be usable only on one connection? I thing because other source packet can drop tunnel when will be sended from other that original connection.
Is there other solution than load balancing?
Thank you
Urbanek
17 Replies 17
Yes you right but I search and read meny discusions, but it was not clear for me, so I ask directly.
If will each connection from diferent ISP there will route cost work "better" and can expect spreaded using of both connections.
It will work as described before, same or different ISPs does not make a difference.
ok thanks,
