Multiples AS-Numbers on ASR1K or ASR9K
I want to know, if it is possible to create multiples BGP AS Numbers on a ASR1K6 Router or ASR9K6 Router.
Thanks.
Marwan ALshawi
I don't think you can on both
However by using bgp local-as command and you present your local bgp AS number with different numbers to different peers
Not possible,you can runn only one BGP process per router,basicaly mean one AS,but as he mentioned in previous
post u can change u r local AS or you can do "AS path prepending" (Add more AS numbers in to the path list ).
BR,
shehin.pm
Ok, thanks for your help.
