How do you upgrade the firmware on an SRW2048 switch?
jwilliams
It baffles me because the admin console doesn't look like it will browse your computer for a firmware update.  Rather, it prefers you to specify a tftp or http server.  I don't know how I'd set up my computer to be the http or tftp server and it doesn't really go into detail on what configurations or commands that would need to be used.
I've used a tftp client in the past to send a firmware to routers and whatnot but not serve one
Peter Paluch
Hello Andrew,
Check this URL for a free TFTP server:
http://tftpd32.jounin.net/
It is fairly easy to set up, and allows you to server the firmware to your switch.
Best regards,
Peter
