MX67 and Stateful Firewall Throughput
We have just upgraded our broadband line to 900Mbps but we are barely getting 400-450Mbps. I have noticed that the MX67 has a Stateful Firewall Throughput of 450Mbps is this is what's limiting us to get a higher speed?  To achieve the 900Mbs would we need to upgrade to a MX75 with a 1Gb throughput?
balaji.bandi
If you lookin 1GB , suggest to go with MX 250, (bare in mind when you buy meraki with License, that can not transfered to other devices) you need to buy fresh with new model, so when you planning, plan correct looking at the future requirement :
https://meraki.cisco.com/en-uk/product/security-sd-wan/small-branch/mx67/
BB
Giuseppe Larosa
Hello @ScottCotterell26321 ,
yes it is likely the MX67 to be too "smal"l for a 1 Gbps link
Each feature you enable will reduce performance so consider this.
Hope to help
Giuseppe
balaji.bandi
BB
