My ATM 0 interface is down
meccax1101
hello
i had read the forum looking to get some answer about my problem
the thing is that the router was working perfect and
suddenly ATM 0 when down.....
my ISP provider came to my office and checked the line with modem and the modem work perfect
he told me that the ATM 0 is broke or something
i had tried the follow commands
dsl operating-mode ansi-dmt
show dsl interface
show controllers atm
this is my config
User Access Verification
Password:
INAVI>enable
Password:
Password:
INAVI#show run
Building configuration...
Current configuration : 1507 bytes
version 12.4
no service pad
hostname INAVI
boot-start-marker
boot-end-marker
enable secret 5 $1$n5Oz$rIs2sArvaC9WvwlmXIzuO.
no aaa new-model
dot11 syslog
no ip dhcp use vrf connected
ip dhcp pool CLIENT
   import all
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   dns-server 196.3.81.5 196.3.81.132
   domain-name codetel.net.do
   lease 0 2
ip cef
archive
log config
  hidekeys
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/33
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer1
mtu 1488
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username 8092201111 password 0 8092201111
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
access-list 102 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password fluke
logging synchronous
login
scheduler max-task-time 5000
end
thank you
15 Replies 15
Hamid Amir
I just have same problem, my atm0.1 down.
Is there any solution for this?
