My Lan Devices is ping but no Internet browsing
Breka
I setup my router Cellular Interface and NAT is should be good and I could ping through my laptop  "10.0.0.2" to "8.8.8.8"
But no browsing internet just ping I tried many things search a lot with no benefits Please HELP me with that
I have Provide my config to understand my router more
Building configuration...
Current configuration : 2482 bytes
! Last configuration change at 02:23:40 UTC Thu Mar 23 2023
version 15.8
sertice timestamps log datetime msecqec
hostname SOKR1
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.158-3.M8.bin
boot-end-marker
no aaa new-model
memory-size iomem 10
ip dhcp pool dh1
default-router 10.0.0.1 255.255.255.0
 dns-server 1.1.1.1
no ip domain lookup
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C898EAG-LTE-GA-K9 sn FCZ2217131X
vtp mode transparent
controller SHDSL 0
controller Cellular 0
vlan 4,100,200,222,456-457,482,555,711
interface Cellular0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string idle-timeout 30
 dialer-group 1
interface Cellular1
 no ip address
 encapsulation slip
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 switchport access vlan 4
 no ip address
intepface GieabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
 interface GigabitEthernet8
 no ip address
 duplex auto
 speed auto
interface Vlal1
 no ip addreqs
 shutdown
interface Vlan4
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 ip tcp adjust-mss 1452
no ip http servercol nd
no ip http secure-server
ip nat ilside source list NAT interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended NAT
 permit ip 10.0.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
 timestamp
control-plane
mecp behavior rsip-ralge tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mecp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 script dialer lte
 no exec
 speed 384000
 no exec
 speed 384000
line vty 0 4
transpmrt input none
scheduler allocate 20000 1000
end
7 Replies 7
M02@rt37
Hello @Breka
Perhaps your are with static IP config on your laptop and not have DNS configured. Please check DNS configuration.
Also, your DHCP configuration is not properly configured on the router.
-- [network] command is not configured.
We expected to have on your DHCP config:
SOKR1(config)#ip dhcp excluded-address 10.0.0.1
SOKR1(config)#ip dhcp pool dh1
SOKR1(dhcp-config)#network 10.0.0.0 255.255.255.0
SOKR1(dhcp-config)#default-router 10.0.0.1
SOKR1(dhcp-config)#dns-server 1.1.1.1
Info:
[Lease] command also could be added on your DHCP pool configuration.
-- add command: lease {days [hours] [minutes] | infinite}
@Flavio Miranda have just confirmed what I suppose.
Thanks for your action @Breka, and please tell us if it's OK for you.
Best regards
ping 8.8.8.8 and cannot access internet meaning the DNS is wrong,
what is 1.1.1.1 DNS server is it your private or this DNS receive from SP ?
@MHM Cisco World
1.1.1.1 == CLOUDLFARE DNS
Best regards
 The problem is that your laptop might not have DNS configured. If you labtop is working with static ip address, you need to enter the DNS manually. If the laptop is working with DHCP, you DHCP server might inform the DNS.
Your DHCP is not properly configured on the router so I am assuming the laptop is not getting IP address from this rotuer.
Proper DHCP setup would look like:
Router(config)#ip dhcp excluded-address 10.0.0.1 10.0.0.10
Router(config)#ip dhcp pool mypool
Router(dhcp-config)#network 10.0.0.0 255.255.255.0
Router(dhcp-config)#default-router 10.0.0.1
Router(dhcp-config)#dns-server 8.8.8.8
Breka
@Flavio Miranda  M02@rt37  @MHM Cisco World
THANKS you all it's worked now but I still have a problem which is the browsing is too slow and down a lot times my connected Meraki Device to router reported me DNS problems that causing the connectivity problems.
Note: My ISP provider "interface cellular 0" forcing me using his own DNS which is 197.199.225.11 , 197.199.225.12
So now we solve the DNS server issue since site nmae is resolve
The issue of slow I think you need to config
Ip tcp adj-mss to be 1380 or 1360
This will force the tcp session to use the mss you config and hence reduce the fragment of packet pass through router.
in addition to the other posts, you can also change the NAT access list, as well as delete the redundant Vlans:
--> no vlan 100,200,222,456-457,482,555,711
--> no ip nat inside source list NAT interface Cellular0 overload
--> no ip access-list extended NAT
--> ip nat inside source list 1 interface Cellular0 overload
--> ip access-list 1 permit 10.0.0.0 0.0.0.255
