In which case cisco switch require to upgrade license
krahulbgp
 In which case cisco switch require to upgrade the  license
instead if I upgrade ios  will it work ?
Richard Burts
You ask a very broad question without providing any context (what type of switch, what is current version of software, what is current feature set/license, what will be new version of software and feature set/license). I will respond in very general terms: for most Cisco switches and most versions of software, and most licenses/feature sets once it is established and running the license will not need to be upgraded.
Rick
Leo Laohoo
In addition to @Richard Burts' comments:
NOTE:
  1. Not all switch models support license upgrade.  For instance, switches with LAN-Lite license cannot be upgraded.  LAN Base license, the "lowest" license, can be upgraded.
  2. SSH/crypto does not require a license upgrade.
The only time a switch's license needs to be upgraded is when there is/are feature(s)/function(s) needed in which the current license is not suffice, such as VSS, routing, VRF/MPLS, etc.
