N3K-C3064TQ-10GT
billybong
Hi All, i have the above switch but it only shows 32 port active license in the show license
NAME: "Chassis", DESCR: "Nexus3064T Chassis"
PID: N3K-C3064TQ-10GT  , VID: V01 ,
switch# sh lic us
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
16P_UPG_PKG                   No    -   Unused             -
32P_LIC_PKG                   Yes   -   Unused Never       -
LAN_BASE_SERVICES_PKG         Yes   -   Unused Never       -
ALGO_BOOST_SERVICES_PKG       No    -   Unused             -
LAN_ENTERPRISE_SERVICES_PKG   No    -   Unused             -
I have tried looking around Cisco but can't see the 16 port upgrade license for the switch
would anyone be able to confirm  i don't need a license upgrade for me to use all 48 ports
Many Thanks
Billy
ahmedshoaib
Level 4
Level 4
Hi;
Please find the required information below:
N3K-C3064TQ-10GT -- Nexus 3064-T, 48 10GBase-T and 4 QSFP+ ports
Cisco Nexus 3064-T
  • 48 fixed 10GBASE-T ports (can operate at 100-Mbps, 1-Gbps, and 10-Gbps speeds)
  • Four fixed QSFP+ ports (each QSFP+ port can support 4 x 10 Gigabit Ethernet or 40 Gigabit Ethernet)
If your Switch is Cisco Nexus 3064-32T
  • 32 fixed 10GBASE-T ports (can operate at 100-Mbps, 1-Gbps, and 10-Gbps speeds)
  • Upgrade to 48 fixed 10GBASE-T and 4 QSFP+ ports by installing a 16-port upgrade license
3064-32T required 16 port below upgrade license.
N3064T-16T-UPG= -- 16 Port Upgrade License for N3064-32T
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-651097.html
Thanks & Best regards;
ahmedshoaib
Level 4
Level 4
Hi;
Cisco Nexus 3064-T
