N7K Hashing Algorithm
ar
Anyone knows the Nexus hashing algorithm for the following:
1. Etherchannel hashing alrogorithm of Nexus 7000 particularly linecard N7K-M108X2-12L?
2. Equal cost multipath hashing?
Don't know if this will help:
Cisco Nexus 7000 vPC Load-Balancing Options
vPC(config)#port-channel load-balance ethernet ?
dest-ip-port Destination IP address and L4 port
dest-ip-port-vlan Destination IP address, L4 port and VLAN
destination-ip-vlan Destination IP address and VLAN
destination-mac Destination MAC address
destination-port Destination L4 port
source-dest-ip-port Source & Destination IP address and L4 port
source-dest-ip-port-vlan Source & Destination IP address, L4 port and VLAN
source-dest-ip-vlan Source & Destination IP address and VLAN
source-dest-mac Source & Destination MAC address
source-dest-port Source & Destination L4 port
source-ip-port Source IP address and L4 port
source-ip-port-vlan Source IP address, L4 port and VLAN
source-ip-vlan Source IP address and VLAN
source-mac Source MAC address
source-port Source L4 port
src-ip Src IP Addr
src-mac Src Mac Addr
src-mixed-ip-port Src IP Addr and TCP/UDP Port
src-port Src TCP/UDP Port
I don't know what the default would be but I guess this will be a good start for you....
What if Im using just a single N7K? No VPC?
I believe you can just add L4 to the hashing.
Catch is, my destination IP will be a single VIP of the application.
So more or less, it will eat up a single link.
I'm thinking of using L3 ECMP instead if it might give a better hashing than etherchannel bundles.
