N9372 config NTP not succeed
zwgff
HI, everybody, I set on a cisco N9372 switch config NTP, show that why not to take effect.
NXOS image file is: bootflash:///n9000-dk9.7.0.3.I1.1a.bin
config:
Feature ntp
clock timezone CST 8
ntp server 10.104.240.21 prefer
ntp server 10.104.240.22
ntp source-interface  loopback0
show ntp status:
Distribution : Disabled
Last operational state: No session
The configuration have what problem, what else need to modify, thank you for your attention!
Martin Hruby
Hello
Can you please post the output of show ntp peer-status ?
Best regards,
Martin
hello
CS9372A# show ntp peer-status
Total peers : 2
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote               local                 st   poll   reach delay   vrf
*10.104.240.21          10.104.240.3            8   64     377   0.00066 default
=10.104.240.22          10.104.240.3           16   64       0   0.00000 default
Best regards,
Hello
Your configuration is correct, the device is synchronizing with 10.104.240.21 as indicated by the output of show ntp peer-status.
On some NX-OS versions you can also verify this using show clock where NTP is reported as the time source.
Best regards,
Martin
Hello, thank you very much
