Name servers selection
parijatkumar
Hi all,
I have two wan connection from two different ISPs.
I am confused how to configure name servers in this case.
Thanks in advance.
sean_evershed
Level 7
Level 7
A cheap and quick solution is to point your PCs to one of the public DNS servers like the one provided by Google
https://developers.google.com/speed/public-dns/
Don't forget to rate posts that are helpful.
The suggestion from Sean to use a public DNS such as the ones offered by Google could be a good solution and should work independently of which provider link your traffic goes out. Another possible solution would be to configure two name servers on your router with one from each ISP, assuming that both ISPs have given you addressing for name servers that they offer.
Rick
Rick
parijatkumar
thanks guys...
it helped ...
