Problem with BGP session
Hello Colleagues,
I set up a scenario for the GNS studies, I have problem when trying to close a sessionwith another BGP peer that is not directly connected to the Router. The protocol used toreach and Peer OSPF, Ja realized ping test between these routers, I can access bothSSH and Telnet but not BGP session closes. Below is the topology. BGP is configuredbetween the R6 and R9 being that I can access via TELNET by R6 R9 and vice versa.Since already I thank you.
nkarpysh
Hi Tiago,
Did not get your problem fully. Can you please attach some logs showing what you dod and showing what problem do you have.
Have you you tried configuring:
neighbor X shutdown
Have you tried "clear ip bgp *"
Have you tried "clear tcp ..."?
Nik
HTH,
Niko
milan.kulik
Level 10
Level 10
what is your problem exactly?
To close a BGP session? As Nikolay said, neighbor ... shutdown would fix it.
Or to open a BGP session? In you case, neighbor ... ebgp multihop might be necessary, see
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_n1g.html#wp1037550
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_n1g.html#wp1037550for details.
HTH,
Milan
