Named EIGRP Address Family IPV6.
Mrfall
Hello all,
I am trying to implement Named EIGRP IPV6.
I notice that by default when i enable EIGRP all the interfaces will particbate in EIGRP. the problem that there is one interface connected to External route. i tried to redistribute inside the EIGRp but i still see it as EIGRP AS not as EXternal route. How can i stop this interface to particpate with EIGRP NAMEd Address family IPV6
Still Learning.
Shutdown the interface under the address-family. For example, if your eigrp name is "NAMED", AS is 1, and interface is Gi1/0/1, the command should be as follows:
router eigrp NAMED
address-family ipv6 unicast as 1
af-interface Gig1/0/1
shutdown
end
When you run "shutdown" under af-interface what it basically does is stopping the interface from participating in EIGRP process.
HTH,
Meheretab
HTH,
Meheretab
router eigrp NAMED
shutdown
end
HTH,
Meheretab
HTH,
Meheretab
