Named EIGRP - Route Redistribution
secureitgroup
I am struggling with this, I have a scenario were I need to redistribute (selective) static routes into Named EIGRP.  Because the nature of needing to be selective I am using a route-map which identifies the routes with a prefix list (also tried acl).
I am able to get this working in classic eigrp but not named.
Here is the router doing the static route redistribution:
HQ# show run
!Command: show running-config
!Time: Tue Apr 19 12:43:11 2022
version 7.0(3)I7(1)
hostname HQ
vdc HQ id 1
  limit-resource vlan minimum 16 maximum 4094
  limit-resource vrf minimum 2 maximum 4096
  limit-resource port-channel minimum 0 maximum 511
  limit-resource u4route-mem minimum 248 maximum 248
  limit-resource u6route-mem minimum 96 maximum 96
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
feature eigrp
feature interface-vlan
username admin password 5 *******
0  role network-admin
ip domain-lookup
snmp-server user admin network-admin auth md5 0x9f0c7803b35eae9f64c1ed6e3f14cc27
priv 0x9f0c7803b35eae9f64c1ed6e3f14cc27 localizedkey
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
vlan 1
ip prefix-list REDISTRIBUTE-STATIC-INTO-EIGRP seq 5 permit 10.6.16.0/28
ip prefix-list REDISTRIBUTE-STATIC-INTO-EIGRP seq 10 permit 10.6.16.16/28
route-map REDISTRIBUTE-INTO-EIGRP permit 5
  match ip address prefix-list REDISTRIBUTE-STATIC-INTO-EIGRP
vrf context management
interface Vlan1
interface Ethernet1/1
  no switchport
  ip address 10.0.33.2/24
  ip router eigrp TEST
  no shutdown
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface mgmt0
  vrf member management
interface loopback0
  ip address 2.2.2.2/32
interface loopback1
  ip address 2.2.2.3/32
line console
line vty
ip route 0.0.0.0/0 10.250.250.2
ip route 9.1.1.0/30 10.250.250.2
ip route 10.0.16.0/32 10.250.250.2
ip route 10.6.16.16/28 10.250.250.2
router eigrp TEST
  distance 90 109
  address-family ipv4 unicast
    autonomous-system 16
    default-metric 1000 100 250 100 1500
    redistribute static route-map REDISTRIBUTE-INTO-EIGRP
here is the peer, I do have eigrp neighborship and learn routes of loopbacks
SITE-A# show run
!Time: Tue Apr 19 12:43:43 2022
version 7.0(3)I7(1)
hostname HQ
vdc HQ id 1
feature eigrp
username admin password 5 ***************
1  role network-admin
ip domain-lookup
snmp-server user admin network-admin auth md5 0xa6fc085745d7b61571db865f55aaa92d
priv 0xa6fc085745d7b61571db865f55aaa92d localizedkey
vlan 1
  no switchport
  ip address 10.0.33.3/24
  no shutdown
interface mgmt0
interface loopback0
  ip address 1.1.1.1/32
interface loopback1
  ip address 1.1.1.3/32
line console
line vty
router eigrp TEST
  distance 90 109
BCCO#  show ip route
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
1.1.1.1/32, ubest/mbest: 2/0, attached
    *via 1.1.1.1, Lo0, [0/0], 14:26:07, local
    *via 1.1.1.1, Lo0, [0/0], 14:26:07, direct
1.1.1.3/32, ubest/mbest: 2/0, attached
    *via 1.1.1.3, Lo1, [0/0], 14:14:17, local
    *via 1.1.1.3, Lo1, [0/0], 14:14:17, direct
2.2.2.2/32, ubest/mbest: 1/0
    *via 10.0.33.2, Eth1/1, [90/130816], 00:18:16, eigrp-ADVIA, internal
2.2.2.3/32, ubest/mbest: 1/0
10.0.33.0/24, ubest/mbest: 1/0, attached
    *via 10.0.33.3, Eth1/1, [0/0], 14:30:46, direct
10.0.33.3/32, ubest/mbest: 1/0, attached
    *via 10.0.33.3, Eth1/1, [0/0], 14:30:46, local
I figured this out, this was a GNS3 lab, so my next hop address on the static route was not up as this was a rough test....
I reached out to a old college, and explained how all seems good with the config and I keep coming back to the EIGRP basics, for it to be advertised the route needs to be up.  I however told myself for the last 36 hours a default route (0.0.0.0 0.0.0.0 x.x.x.x) is not up but I wasn't thinking about the next hop address that in fact is up.
I am glad I was able to focus my troubleshooting at the EIGRP fundamentals but ashamed I did not make sure the next hop was up.
5 Replies 5
 Probably not the problem but the first prefix list does not match with the respective route
Any specific reason to use this kind of EIGRP?
Jon Marshall
Are the routes in the EIGRP topology table on the peer ?
If so can you post output.
Jon
router eigrp TEST
 address-family ipv4 autonomous-system 16
 af-inteface  Fx/x .....etc.
try this way
If you want next time config static route with Null0 this make static route always UP.
And I glad your issue solved.
good luck friend
