Naming vlan in cisco Swouter (Router having etherswitch module)
Dragneel98
Using the following command,
Router#vlan database
Router(vlan)#vlan 10
   VLAN 10 added:
How do I manually change this name to any desired name ?
[I'm using Packet Tracer 2811 Router having HWIC-4ESW module]
TJ-20933766
Use the following commands:
Router(vlan)#vlan 10 name DATA
Using the key word "name" after the VLAN number followed by what you want to call the VLAN will allow you to change it.
TJ-20933766
Thanks Tyson.
I had a confusion that instead of using an ESW/ES module in the 2811 router, why can't I create vlan in the global config mode.
