NAT all Lan range traffic to Tunnel - Source NAT cisco router C2900
omid-nami
I need to NAT LAN range to a single IP tunnel:
this is my config:
LAN Range: 192.168.180.0/24 (Gi 0/2)
WAN: 172.21.21.208/252  (Gi 0/1)
Tunnel IP's: 192.168.226.177/252
Destination network to connect through the tunnel: 172.17.100.0/24
the tunnel is UP and I can ping 192.168.226.177 (another side of the tunnel) from LAN, but I cannot reach 172.17.100.0/24 range
this is my running config:
interface Tunnel680
ip address 192.168.226.178 255.255.255.252
ip access-group 101 in
ip nat outside
ip virtual-reassembly in
tunnel source 172.21.21.210
tunnel destination 172.17.11.30
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.21.21.210 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 192.168.180.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Tunnel680 overload
ip route 0.0.0.0 0.0.0.0 172.21.21.209
access-list 101 permit ip any any
access-list 101 permit ip 172.17.100.0 0.0.0.255 any
please help me to solve the problem
2 Accepted Solutions
access-list 101 permit ip any any <<- remove this
Second there is no traffic route toward the tunnel ??
MHM
Hello @omid-nami
You need two things regarding static routes:
1 for tunnel is up:
ip route 172.17.11.30 255.255.255.255 172.21.21.209
Second one in order to route flow through the tunnel:
ip route 0.0.0.0 0.0.0.0 tunnel680
Best regards
8 Replies 8
M02@rt37
Hello @omid-nami
As concerned your default route: ip route 0.0.0.0 0.0.0.0 172.21.21.209
It should be ip route 0.0.0.0 0.0.0.0 tunnel680 ?
Best regards
if I change default route from wan's GW to the tunnel, Tunnel goes down
Hello @omid-nami
1 for tunnel is up:
Best regards
Thank you so much, now all traffic goes to the tunnel, but Still cannot reach 172.17.100.0/24, whats wrong???
You're welcome @omid-nami
On the other router, what about the routing ?
Best regards
The other router is in headquarter office and I dont have access to the configuration, they just sent me wan and tunnel IP's, I want to be sure of my routers configuration, then call them for trobleshoot
best regards
MHM
I've tried this:
Ip route 172.17.100.0 255.255.255.0 192.168.226.177
but it doesnt work
