NAT and Extended ACLs
Peter.D.Brown
Hi there,
I'm investigating an issue involving NAT and I'm unsure what gets translated to what based on the following config (from Cisco IOS NAT on a 6500 switch). I was under the impression that NAT used standard access lists but this one's an extended. The NAT uses the same access-list that's applied to control access through the interface (with the access-group command).
I'm sure this must be a valid config as it's been in place for a long time. Does it mean that when a packet comes into the interface designated as 'outside' (Fa3/43) that the source address of it will be NATed to something in the NAT pool as long as the destination and the port equal something in the access list? Taking the first line as an example (and let's just say that there is only one line) does it mean that if a tcp packet comes from host 172.19.198.42 destined for host 10.162.53.32 and on port 21 then it will have the source address NATed, and if it doesn't match all of these criteria then it won't be NATed?
Thanks in advance for any advice.
interface Vlan2
ip address 10.162.52.253 255.255.252.0
ip nat inside
interface FastEthernet3/7
ip address 10.162.254.77 255.255.255.252
ip nat inside
interface FastEthernet3/43
ip address 10.162.244.1 255.255.255.248
ip access-group monitor-servers in
ip nat outside
ip nat pool nat_pool_1 10.162.244.65 10.162.244.125 netmask 255.255.255.192
ip nat outside source list monitor-servers pool nat_pool_1
ip access-list extended monitor-servers
permit tcp host 172.19.198.42 host 10.162.53.32 eq ftp
permit tcp host 172.19.198.42 host 10.162.53.73 eq ftp
permit tcp host 172.19.198.42 host 10.162.53.74 eq ftp
permit tcp host 172.19.198.42 host 10.162.20.30 eq ftp
permit tcp host 172.19.198.42 host 10.162.53.32 eq telnet
permit tcp host 172.19.198.42 host 10.162.53.73 eq telnet
permit tcp host 172.19.198.42 host 10.162.53.74 eq telnet
permit tcp host 172.19.198.42 host 10.162.20.30 eq telnet
permit tcp host 172.19.198.42 host 10.162.53.32 eq 1433
permit tcp host 172.19.198.42 host 10.162.53.73 eq 1433
permit tcp host 172.19.198.42 host 10.162.53.74 eq 1433
permit tcp host 172.19.198.42 host 10.162.20.30 eq 1433
permit tcp host 172.19.198.42 host 10.162.53.32 eq 1721
permit tcp host 172.19.198.42 host 10.162.53.73 eq 1721
permit tcp host 172.19.198.42 host 10.162.53.74 eq 1721
permit tcp host 172.19.198.42 host 10.162.20.30 eq 1721
permit tcp host 172.19.198.42 host 10.162.53.32 eq 4105
permit tcp host 172.19.198.42 host 10.162.53.73 eq 4105
permit tcp host 172.19.198.42 host 10.162.53.74 eq 4105
permit tcp host 172.19.198.42 host 10.162.20.30 eq 4105
permit tcp host 172.19.198.42 host 10.162.53.32 eq 7001
permit tcp host 172.19.198.42 host 10.162.53.73 eq 7001
permit tcp host 172.19.198.42 host 10.162.53.74 eq 7001
permit tcp host 172.19.198.42 host 10.162.20.30 eq 7001
permit tcp host 172.19.198.42 host 10.162.53.32 eq 7003
permit tcp host 172.19.198.42 host 10.162.53.73 eq 7003
permit tcp host 172.19.198.42 host 10.162.53.74 eq 7003
permit tcp host 172.19.198.42 host 10.162.20.30 eq 7003
permit tcp host 172.19.198.42 host 10.162.53.32 eq 7774
permit tcp host 172.19.198.42 host 10.162.53.73 eq 7774
permit tcp host 172.19.198.42 host 10.162.53.74 eq 7774
permit tcp host 172.19.198.42 host 10.162.20.30 eq 7774
permit udp host 172.19.198.42 host 10.162.53.32 eq snmp
permit udp host 172.19.198.42 host 10.162.53.73 eq snmp
permit udp host 172.19.198.42 host 10.162.53.74 eq snmp
permit udp host 172.19.198.42 host 10.162.20.30 eq snmp
permit udp host 172.19.198.42 host 10.162.53.32 eq snmptrap
permit udp host 172.19.198.42 host 10.162.53.73 eq snmptrap
permit udp host 172.19.198.42 host 10.162.53.74 eq snmptrap
Edison Ortiz
That's correct.
__
Edison.
Edison Ortiz
That's correct.
__
Edison.
