PBR problem
mtebaccount
Good evening everybody . I have some strange problem with PBR setup on 3825 .
Here is the part of the config :
interface GigabitEthernet0/0.X
encapsulation dot1Q X
ip address x.x.x.x
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
zone-member security DMZ
ip policy route-map fbsd
route-map fbsd deny 5
match ip address fbsd_exc
route-map fbsd permit 10
match ip address fbsd1
set ip next-hop 1.1.1.2
route-map fbsd permit 20
match ip address fbsd2
set ip next-hop 1.1.1.3
And everything works fine , but after router restart i have to manually ping every next-hop from the router to make PBR work . Is there something ive missed ? Thanks in advance , Dmitriy.
Giuseppe Larosa
Hello Dmitriy,
After reload the ARP cache of your router is empty and the router doesn't know the MAC address of the next-hops.
You could:
use BFD to create a communication with the next-hops (preferred)
or hardcode the MAC address
Hope to help
Giuseppe
Giuseppe Larosa
Hello Dmitriy,
You could:
Hope to help
Giuseppe
Hello, Giuseppe.
Actually i can see my next-hop mac adresses in arp table after reload , so i guess there is something else .
EDIT:
Actually my mistake , this really was the arp problem . Thanks for help.
Thanks in advance. Dmitriy.
