NAT and internal WebServer
niLuxx
Dear community,
I know this question was asked a couple of times already, but nevertheless I couldn't manage it to get it running.
I have the following setup
INTERNET <=> ASA5508-X <=> Internal-Web-Server
We just have one public ip, that is assigned to outside-interface of the ASA5508-X. Our internal WebServer is listening on port 5555.
The intention is to access the internal-web-server via internet.
In this regards I did the following config:
object network network_dmz
subnet 192.168.5.0 255.255.255.0
object network reverse_proxy
host 192.168.5.2
object network vpn
host 192.168.1.103
nat (outside,dmz) source static any any destination static reverse_proxy reverse_proxy service upload_in upload_in no-proxy-arp
Manual NAT Policies (Section 1)
3 (dmz) to (outside) source static network_dmz network_dmz destination static vpn vpn no-proxy-arp
translate_hits = 39, untranslate_hits = 39
Source - Origin: 192.168.5.0/24, Translated: 192.168.5.0/24
Destination - Origin: 192.168.1.103/32, Translated: 192.168.1.103/32
Auto NAT Policies (Section 2)
2 (dmz) to (outside) source dynamic network_dmz interface
translate_hits = 16, untranslate_hits = 0
Source - Origin: 192.168.5.0/24, Translated: [IP]/32
1 (outside) to (dmz) source static any any destination static reverse_proxy reverse_proxy service upload_in upload_in no-proxy-arp
translate_hits = 0, untranslate_hits = 0
Source - Origin: 0.0.0.0/0, Translated: 0.0.0.0/0
Destination - Origin: 192.168.5.2/32, Translated: 192.168.5.2/32
Service - Origin: tcp source eq 9555 , Translated: tcp source eq 9555
8 (outside) to (outside) source dynamic vpn interface
translate_hits = 2585, untranslate_hits = 34
Source - Origin: 192.168.1.103/32, Translated: [IP]/32
1 (outside) to (outside) source dynamic network_backbone interface
Source - Origin: 192.168.1.0/24, Translated: [IP]/32
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list outside-inbound; 6 elements; name hash: 0x493b324d
access-list outside-inbound line 6 extended permit tcp any object reverse_proxy eq www (hitcnt=1) 0x9c24c3b7
access-list outside-inbound line 6 extended permit tcp any host 192.168.5.2 eq www (hitcnt=1) 0x9c24c3b7
Any idea to get that running.
Greetings,
niLuxx
19 Replies 19
Sorry, i have overseen the packet-tracer comment:
Here is the output (hopefully that makes sense).
ciscoasa# packet-tracer input outside tcp 8.8.8.8 12345 192.168.5.2 9555
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 192.168.5.2 using egress ifc dmz
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: dmz
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Sorry, I also had to adjust the ACE for real port:
access-list outside-inbound line 6 extended permit tcp any object reverse_proxy eq 9555 (hitcnt=0) 0x84bb306f
access-list outside-inbound line 6 extended permit tcp any host 192.168.5.2 eq 9555 (hitcnt=0) 0x84bb306f
Here is the packet tracer output:
Just for info. I'm connect to system via VPN (maybe that influences the packet tracer).
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside-inbound in interface outside
access-list outside-inbound extended permit tcp any object reverse_proxy eq 9555
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (dmz,outside) dynamic interface
Result:
input-status: up
output-status: up
Action: drop
Here is your problem:-
This needs to be below your more specific nat rule
EDIT: For example, you could remove that nat entry for network_dmz object and create the nat rule globally and define it as "after-auto".
nat (DMZ,OUTSIDE) after-auto source dynamic network_dmz interface
ASA(config)# show nat
1 (DMZ) to (OUTSIDE) source static reverse_proxy interface  service tcp 9555 10555
Manual NAT Policies (Section 3)
1 (DMZ) to (OUTSIDE) source dynamic network_dmz interface
Manual NAT (Section 3) nat rules will be processed after the more specific Auto NAT rule for your reverse_proxy.
this already is below the more specified NAT rule. Furthermore I disabled all other DMZ-NAT rules. But still no success. Inside the ASA log (ASDM, first page), I cannot even see a message when I try to access the ASA with this specific port. If I'm using the port 443 (VPN), it is showing a message. That's the reason why I assume, that something other has to be the cause. Maybe there is a rule on ASA site, prohibits every connection, instead of VPN and SIP calls (fritzbox)?! No idea...
Best regards,
niLuxx
Then please share running configuration of the device.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
