NAT config problem
ok so this is my network. I tried to config overload NAT on R1
FIX: R3 connect to R1 in f 3/0 and not f 2/0
R1 config:
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface ATM1/0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet2/0
no ip address
shutdown
duplex half
interface FastEthernet3/0
ip address 11.0.1.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet3/1
ip address 10.1.3.2 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip route profile
ip route 0.0.0.0 0.0.0.0 11.0.1.2
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet3/0 overload
logging alarm informational
access-list 1 permit 10.1.3.0 0.0.0.255
no cdp log mismatch duplex
route-map WORD permit 10
description
description LINE
continue
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3 config:
upgrade fpd auto
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
archive
log config
hidekeys
no ip address
shutdown
duplex half
interface ATM1/0
no ip address
shutdown
no ip address
shutdown
duplex half
ip address 11.0.1.2 255.255.255.0
duplex auto
speed auto
ip address 11.0.0.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
interface Serial5/0
no ip address
shutdown
serial restart-delay 0
interface Serial5/1
no ip address
shutdown
interface Serial5/2
no ip address
shutdown
interface Serial5/3
no ip address
shutdown
interface Serial6/0
no ip address
shutdown
interface Serial6/1
no ip address
shutdown
interface Serial6/2
no ip address
shutdown
interface Serial6/3
no ip address
shutdown
interface Serial6/4
no ip address
shutdown
interface Serial6/5
no ip address
shutdown
interface Serial6/6
no ip address
shutdown
interface Serial6/7
no ip address
shutdown
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
and the pc config:
set pcname PC-1
ip 10.1.3.4 10.1.3.2 24
when I ping from the pc to R3 i dont see any trafic on the line betwwen R1 to R3. the PC send the request to R1 and its stack there.
R1#sh ip nat translations
Pro Inside   global Inside local Outside local Outside global
icmp 11.0.1.1:22507 10.1.3.4:22507 11.0.1.2:22507 11.0.1.2:22507
icmp 11.0.1.1:23019 10.1.3.4:23019 11.0.1.2:23019 11.0.1.2:23019
icmp 11.0.1.1:23531 10.1.3.4:23531 11.0.1.2:23531 11.0.1.2:23531
the nat table look fie so were is the problem?
Hello
you nat config looks fine the only thing that stands out is R3 ip address is configured on the wrong interface looking at the topology and you R3 configuration
res
paul
Kind Regards
Paul
Hello
res
paul
Kind Regards
Paul
thenks, it solve one problem, now i can ping from R1 to R3 but somthing stiil dont work. I can't ping from the PC to R3. i can ping from R1 sorce 10.1.3.2 to R3 so the NAT work, but somthing else is broken.
Hello
Does your client have the correct ip addressing details
subnet mask /default gateway
res
Paul
Kind Regards
Paul
