NAT configuration help
bstockslager
Community Member
I'm having troubles getting NAT to work correctly on a router with 4 VLANs configured on it.  This is at an office that is currently dead in the water so I'm kind of scrambling to get things back up.  I'm pretty sure I'm about 95% complete with the router's config, if anyone can take a look and see what I'm missing I'd greatly appricate it.  ##########OMITTED OUTPUT########## is just passwords or other security things.
Building configuration...
Current configuration : 2808 bytes
version 12.4
hostname  ##########OMITTED OUTPUT##########
boot-start-marker
boot-end-marker
enable password  ##########OMITTED OUTPUT##########
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.40.128
ip dhcp excluded-address 10.10.30.128
ip dhcp pool 40
   network 10.10.40.0 255.255.255.0
   default-router 10.10.40.128
   dns-server 8.8.8.8
   lease 4
ip dhcp pool 30
   network 10.10.30.0 255.255.255.0
   default-router 10.10.30.128
   dns-server 8.8.8.8
   lease 4
ip domain name ##########OMITTED OUTPUT##########
ip name-server 8.8.8.8
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username ###########OMITTED OUTPUT##########
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.0.0.62 255.255.255.192
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 10.128.1.129 255.255.255.192
ip nat inside
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 10.10.30.128 255.255.255.0
ip nat inside
interface FastEthernet0/1.40
encapsulation dot1Q 40
ip address 10.10.40.128 255.255.255.0
ip nat inside
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
ip nat pool ovrld 1.1.1.1 1.1.1.1 netmask 255.255.255.240
ip nat pool ovrld2 1.1.1.1 1.1.1.1 netmask 255.255.255.240
ip nat pool ovrld3 1.1.1.1 1.1.1.1 netmask 255.255.255.240
ip nat pool ovrld4 1.1.1.1 1.1.1.1 netmask 255.255.255.240
ip nat inside source list 10 pool ovrld overload
ip nat inside source list 20 pool ovrld2 overload
ip nat inside source list 30 pool ovrld3 overload
ip nat inside source list 40 pool ovrld4 overload
access-list 10 permit 10.0.0.0 0.0.0.63
access-list 20 permit 10.128.1.128 0.0.0.63
access-list 30 permit 10.10.30.0 0.0.0.255
access-list 40 permit 10.10.40.0 0.0.0.255
control-plane
#######OMITED OUTPUT##########
end
bstockslager
Community Member
Also, I forgot to add that traffic on VLAN 1 works, no other VLANs are able to get to the internet though
Hi Blake,
I don't see any flaws right now but I will keep on looking. However, this configuration is strange:
Why wouldn't you just do it without the nat pool? :
ip nat inside source list 10 interface FastEthernet0/0 overload
I have never configured it that way when I used only one IP address, but maybe it is completely allright, haven't tested it so I can't really say.
BUT
I strongly discourage you defining default route in this manner:
With this type of configuration, a router performs ARP on the FastEthernet0/0 for every destination the router finds through the default route because the router considers all of these destinations as directly connected to FastEthernet0/0.
This kind of default route, especially if it is used by a lot of packets to many different destination subnets, can cause high processor utilization and a very large ARP cache (along with attendant memory allocation failures).
instead, please specify the IP address of the next-hop
ip route 0.0.0.0 0.0.0.0 1.1.1.2
(just a guess that 1.1.1.2 is IP of your next-hop router on that interface)
Moreover, with Proxy-ARP disabled on the next-hop router, without specifying default route with IP address on your router, you may even not get outside your network at all!
This may be the root of some ( if not all ) of your problems.
If you want more information regarding this topic, please see
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
One more thing, clarify that the problem lays in NAT by issuing:
show ip nat translations
If you do have correct translations there, the problem is not in NAT configuration, but maybe in the definition of default route.
Please, provide us with the show ip nat translations output. Thanks!
Best regards,
Jan
Umesh Shetty
Level 5
Level 5
Hi Blake,
If you are using the same IP address ie 1.1.1.1 for natting all 4 vlans, can  you try using a single source list with all 4 subnets included in that and the same overload pool rather than using 4 NAT pools and 4 source lists. If you are observing that only Vlan 1 gets natted it maybe the case that only the first NAT pool "ovrld" is functioning and others aren't. Using only a single NAT pool and a Sigle source list will even simplify the config. Please use the config as mentioned below.
access-list 10 permit 10.128.1.128 0.0.0.63
access-list 10 permit 10.10.30.0 0.0.0.255
access-list 10 permit 10.10.40.0 0.0.0.255
Rest of the config looks fine, If you still see issue try correcting the default route as Jan suggested and try avoinding the NAT pool by using the statement below.
HTH !!!
Umesh Shetty
