NAT Destination Addresses of packets from a source pool
allan.sydney
I am trying to nat the destination addresses of packets.
if i use a static nat rule this works.
ip nat outside source static 9.10.11.12 5.6.7.8
so my packets from source address 1.2.3.4 are being sent by their dumb app to 5.6.7.8 and my router is sending rewriting the destination addresses to 9.10.11.12. this is fine.
however, i want only packets from source address 1.1.1.0/24 to be affected by this nat and not all packets.
to try and do this i have created a rotary pool
ip nat pool POOL3 9.10.11.12 9.10.11.12 netmask 255.255.255.0 type rotary
ip nat outside source list acltest pool POOL3
access-list extended acltest
permit ip 1.1.1.1 0.0.0.255 host 5.6.7.8 log
however this doesnt seem to work.
any ideas?
my router is a cisco 2651xm
many thanks
Try using route-map. This is only an example:
ip nat outside source static 9.10.11.12 5.6.7.8 route-map Special_App
route-map Special_App permit 10
match ip address 150
access-list 150 permit ip 1.1.1.1 0.0.0.255 host 5.6.7.8
Best regards.
Have you actually tried applying this config ?
The doc you linked to only uses ip nat inside examples. I have 12.4 and do not have the option for "ip nat outside source static..." with a route-map. It is only available for "ip nat inside source static...".
I agree with your config i'm just not sure it is supported at least not up to 12.4.
Jon
You have right.
Try this:
p nat pool POOL 9.10.11.12 9.10.11.12 netmask 255.255.255.0
ip nat outside source route-map SPEC_APP pool POOL
route-map SPEC_APP permit 10
Bye.
