NAT for no default gateway device
Mario Lessard
      I have a device that I can't add a default gateway but I want a service from this computer from an other network. So I think I have to use NAT. What I did is this:
int tunnel2
ip add 10.1.1.2 255.255.255.0
ip nat outside
int gi0/1
ip add 10.1.2.1 255.255.255.0
ip nat inside
ip nat inside source static tcp 10.1.2.100 6010 10.1.1.2 6010 extendable
So, in the client computer from WAN, I use 10.1.1.2:6010 to communicate with 10.1.2.100:6010.
In this case, the device 10.1.2.100 suppose to answer to 10.1.2.1 (int gi0/1) and than if no gateway on this device it suppose to work?
Let me know if I'm completly wrong.
Thank you
15 Replies 15
Try to use this.
int tunnel2
ip nat inside
int gi0/1
ip nat outside
IP nat inside source static 10.4.2.2  10.1.2.1
You need to have route to 10.1.2.100 on your both router.
