NAT IN/OUT PROBLEM
Didier1966
I have a WEB server running locally , and this work well.
Now I would like to see it from external , but it seams not to work and I do no know what I do wrong.
Here bellow some part of the configuration and the IP NAT TRANSLATION :
ROUTER1841#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
udp 81.164.201.195:1   192.168.1.251:123  66.27.60.10:123    66.27.60.10:123
udp 81.164.201.195:123 192.168.10.50:123  17.72.255.12:123   17.72.255.12:123
tcp 81.164.201.195:49778 192.168.10.50:49778 72.163.5.80:443 72.163.5.80:443
tcp 81.164.201.195:8099 192.168.10.3:80   ---                ---
ROUTER1841#
I can PING the OUTSIDE 81.164.201.195 , but I can not see the WEB page
I have tried different port in case my ISP block some ports , I even try a LINKSYS WRT54GL , where I open the port 8099 and this one was working , so I am sure I do something wrong.
no ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.10.3 80 81.164.201.195 8099 extendable
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 101 permit ip 192.168.30.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
Best Regards,
Didier
3 Accepted Solutions
First  clear dynamic entries in NAT table with clear ip nat translation * command
Then  do a show ip nat translation command to see if indeed your static nat is in the table
Then do a debug ip nat and try to access this webserver so you can see if the nat is used indeed.
Regards.
mrdogantr
Hi Didier,
     Your config is runing.
http://81.164.201.195:8099
and i think you must change your web panel password .
No you can't do this:
Maybe , I can not test from INSIDE to BACK to the ROUTER INSIDE ?
Regards.
7 Replies 7
Can you post your interfaces config? Both inside one and outside one.
Hello Marcin,
Here You have the FULL CONFIG
MAYBE A IMPORTANT INFORMATION :
From OUTSIDE I am able to access the CISCO 1841 ROUTER on PORT 8096 via :
ssh://admin@cisco1841.dyndns.info:8096
This mean that my provider does not lock-out this port.
But this does not work:
http://admin@cisco1841.dyndns.info:8099//admin@cisco1841.dyndns.info:8099
Here bellow I put the IP instead of the name , both are still equal (I DO NOT KNOW YET HOW TO CHANGE THE IP TO admin@cisco1841.dyndns.info:8099
Thank You in advance for your help
NOTE : The script in complete , I have just remove some part of the PASSWORD.
Best Regards,
Didier
! Last configuration change at 23:01:37 gmt+1 Wed Dec 1 2010 by admin
! NVRAM config last updated at 22:59:46 gmt+1 Wed Dec 1 2010 by admin
version 12.4
service password-encryption
hostname ROUTER1841
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password 7 050
aaa new-model
aaa authentication banner
THIS SYSTEM IS SOLELY FOR USE OF AUTHORISED USERS FOR OFFICIAL PURPOSES
aaa session-id common
clock timezone gmt+1 1
clock summer-time gmt+2 recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.100.1
ip dhcp excluded-address 192.168.1.250 192.168.1.254
ip dhcp pool vlan10
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 8.8.8.8
   lease 5
ip dhcp pool vlan20
   import all
   network 192.168.20.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.20.1
   lease 5
ip dhcp pool vlan30
   import all
   network 192.168.30.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.30.1
ip dhcp pool FIX-IP
   host 192.168.100.66 255.255.255.0
   client-identifier 0100.089b.ad17.8f
   client-name FIX-IP
ip dhcp pool TEST
   host 192.168.100.20 255.255.255.0
   client-identifier 0100.2241.353f.5e
ip dhcp pool internal
   network 192.168.100.0 255.255.255.0
   dns-server 192.168.100.1
   default-router 192.168.100.1
ip dhcp pool vlan1
   network 192.168.1.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.1.1
   lease 5
ip dhcp pool MAC
   host 192.168.10.50 255.255.255.0
   client-identifier 0100.2312.1c0a.39
ip dhcp pool PRINTER
   host 192.168.10.20 255.255.255.0
   client-identifier 0100.242b.4d0c.5a
ip dhcp pool WAP610N
   host 192.168.10.100 255.255.255.0
   client-identifier 0100.259c.8fad.4c
no ip bootp server
ip domain name dri
ip host SW12 192.168.1.252
ip host SW24 192.168.1.251
ip ddns update method DynDNS
HTTP
  add http://dri66:@members.dyndns.org/nic/update?system=dyndns&hostname=cisco1841.dyndns.info&myip=
interval maximum 1 0 0 0
interval minimum 1 0 0 0
crypto pki trustpoint TP-self-signed-2996
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-29967
revocation-check none
rsakeypair TP-self-signed-29967
username Admin privilege 15 secret 5 $1$gAFQ
archive
log config
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 8096 rotary 1
ip ssh version 2
description DMZ
ip ddns update hostname cisco1841.dyndns.info
ip ddns update DynDNS
ip address dhcp
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description INTERNAL$ETH-LAN$
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/0/1
switchport access vlan 20
interface FastEthernet0/0/2
switchport access vlan 30
interface FastEthernet0/0/3
switchport mode trunk
interface Vlan1
ip address 192.168.1.250 255.255.255.0
ip nat inside
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
ip dns server
no cdp run
control-plane
banner exec
WELCOME YOU ARE NOW LOGED IN
banner login
WARNING !!!
IF YOU ARE NOT :
Didier Ribbens
Please Leave NOW !!!
YOUR IP and MAC address will be LOGGED !!!
line con 0
speed 115200
line aux 0
line vty 0 4
access-class 5 in
privilege level 15
rotary 1
transport input telnet ssh
line vty 5 15
access-class 5 in
rotary 1
scheduler allocate 20000 1000
ntp clock-period 17178401
ntp server 66.27.60.10
end
Regards.
mrdogantr
Hi Didier,
Really strange , I did not change anything , and YES it works .
I have to tell , now I test it abroad and it works , I am curious if it will work when I am back home ?
If this is the case I will try to login with a other connection at home , my provider give me 4 IP's so I have still 3 others that I can use before the cisco router.
I will keep you informed , in the mean time thank you for the info.
Any idea how I can replace the IP with the URL ADDRESS ?
Best Regards,
Didier
Regards.
Thank You All for your great help
