QOS Policy on WAN Interfaces with speed difference
nedk12345
On a MPLS network when the physical interface speed is higher (100 Mb) and subscribed CIR is lower (50Mb) what qos settings need to be configured on Routers.
Is Traffic shaping configured in inbound or outbound direction or both?
Does it need to be implemented at all sites where speed mismatch occur?
What is difference between shaping and hierarcy qos and is both used together in such scenario?
Is there an example with explanation on commands and how to find shaping value?
tx
Mahesh Gohil
Level 7
Level 7
Shaping is configured in output direction only and sense also.
and good idea to go for shaping where there is speed mismatch so excess of traffic will be buffered in output queue.
In addition you can go with shaping along with hirerchical map
Ex:
policy-map TEST1
class EF
Bandwidth percent 50
class AF12
policy-map PARENT
class class-default
shape average 256000
service-policy TEST1
Mahesh
