NAT in router with access-list
bapatsubodh
Is it possible to do NATing in router depending upon the destination address in Packets. ( that is with help of access lists ). In short if destination address in packet is "A" then is should be NATed with ip pool "A". and then forwarded to corresponding to outbound interface.
In short Destination is "A" then ip pool is "POOL__A",
if Destination is "B" then ip pool
is "POOL__B".
Similar link or examle on cisco.com highly appreciable.
Thanx.
Here's an example:
ip nat pool POOL__A 10.0.0.0 10.0.0.255 netmask 255.255.255.0
ip nat pool POOL__B 10.1.0.0 10.1.0.255 netmask 255.255.255.0
ip nat inside source route-map ToA pool POOL__A
ip nat inside source route-map ToB pool POOL__B
access-list 101 permit ip any
access-list 102 permit ip any
route-map ToA permit 10
match ip address 101
route-map ToB permit 10
match ip address 102
Hope that helps - pls rate the post if it does.
Paresh
