NAT issue. 2 different Inside global IP addresses for one Inside local IP
MaximBudyonny
Hi All,
I need to perform such trick:
One host from inside (inside local) connects to 2 different services binded to 2 different IP addresses (outside global).
I'm trying to do it with such NAT configuration.
for Service1
ip nat pool pool-4-97 10.88.4.97 10.88.4.97 prefix-length 28
Extended IP access list list-97
10 permit tcp host 10.0.0.75 gt 1023 host 172.23.200.11 eq 2323
ip nat inside source list list-97 pool pool-4-97 overload
for Service2
ip nat pool pool-4-100 10.88.4.100 10.88.4.102 prefix-length 28
Extended IP access list list-100
10 permit tcp host 10.0.0.75 gt 1023 host 172.23.100.49 eq 4555
ip nat inside source list-100 pool pool-4-100
When I'm trying to connect from host 10.0.0.75 to 172.23.100.49:4555 I can see
from the output of 'debug ip nat' that Cisco creates NAT translation but translates not to IP address from pool pool-4-100 but to IP address from pool pool-4-97
NAT entry for service1 is upper in Cisco?s config than NAT entry for service 2 and occurred 'first match wins'.
But it?s wrong. Destination hosts are clearly set in the access lists.
How can I enforce NAT to perform translation according to access list?
Can 'ip nat inside source route-map' helps to solve this issue?
MaximBudyonny
OK I changed configuration of NAT entry to
and it works properly.
