NAT issue
albertobrivio
Dear All,
I have a simple configuration, a DSL, some users browsing internet, sending/receiving e-mails, and so on,
and ther's a public web server.
It seems to be all up and running, but in order to publish web server I have to open a lot of tcp ports
other than 80, because web server seems to answer through the port owned by client starting request.
This is the configuration:
webserver 192.168.100.253 , public 212.110.x.y, it's the LAN's proxy server
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no aaa new-model
ip subnet-zero
no ip source-route
!ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 192.168.101.254 255.255.255.0 secondary
ip address 192.168.100.254 255.255.255.0
ip access-group 101 in
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxx
ppp chap password yyyyyyyyyyyyyyyyyyyy
ip nat inside source list 10 interface Dialer0 overload
ip nat inside source static tcp 192.168.100.253 22 212.110.x.y 22 extendable no-alias
ip nat inside source static tcp 192.168.100.253 80 212.110.x.y 80 extendable no-alias
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 10 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
access-list 101 permit icmp any any
access-list 101 permit tcp host 192.168.100.253 any eq domain
access-list 101 permit udp host 192.168.100.253 any eq domain
access-list 101 permit tcp host 192.168.100.253 any eq www
access-list 101 permit tcp host 192.168.100.253 any eq smtp
access-list 101 permit tcp host 192.168.100.253 any eq ftp
access-list 101 permit tcp host 192.168.100.253 any eq pop3
access-list 101 permit tcp host 192.168.100.253 any eq 1433
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq pop3
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq 1433
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq ftp
access-list 101 permit tcp host 192.168.100.253 any range 0 10000 (without this line web is not published)
access-list 101 deny ip any any
line con 0
exec-timeout 120 0
login local
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 30 in
exec-timeout 120 0
login local
scheduler max-task-time 5000
end
Alberto Brivio
5 Replies 5
globalnettech
Level 5
Level 5
Hello Alberto,
which web publishing software/application are you using ? Your problem sounds like it could be related to your web publishing software, rather than the router...
GNT
that environment is managed by a customer of mine, but I know paltform is:
APACHE 2.0.52 DEBIAN GNU/Linux
If I enable log to ACL's line I have to write, you can see output here:
9w5d: %SEC-6-IPACCESSLOGP: list 101 permitted tcp 192.168.100.253(80) -> remote client address(3269), 1 packet
9w5d: %SEC-6-IPACCESSLOGP: list 101 permitted tcp 192.168.100.253(80) -> remote client address(3273), 1 packet
Alberto
The problem is not with the webserver. The webserver is responding just the way it should; using tcp 80 as the source port and the client's port as the destination port. The problem is with the way you have configured and applied the access-list. Usually in order to protect your internal LAN you apply a restrictive access-list on the outside interface in inbound direction. That way you can allow access to port 80 for your webserver but deny access to all other internal hosts.
My recommendation is to only have a non-spoofing access-list on your inside interface and have a more restrictive access-list on the outside interface. An example is:
ip access-list extended inside
permit ip 192.168.100.0 0.0.0.255 any
permit ip 192.168.101.0 0.0.0.255 any
deny ip any any log
ip access-list extended outside
permit tcp any 192.168.100.0 0.0.0.255 established
permit tcp any 192.168.101.0 0.0.0.255 established
permit udp any eq dns 192.168.100.0 0.0.0.255
permit udp any eq dns 192.168.101.0 0.0.0.255
permit tcp any host 212.110.x.y eq www
permit tcp any host 212.110.x.y eq ssh
This ACL might break some applications so you have to do some fine tuning after applying it inbound on Dialer0. You can put a deny ip any any log statement at the end of the outside ACL to see if legitimate traffic is being denied and if it is then add the respective entry in the ACL.
If you want to stick with your ACL then you do not have much choice but to add a statement of this sort:
access-list 101 permit tcp host 192.168.100.253 eq www any
thanks for your reply.
I'm going to try your tips.
Normally I manage Pix IOS,so in router environment I don't have much familiarity, but opening all outbound connections on eth0 and permit tcp established incoming on dialer 0..couldn't it be dangerous?
I agree about my much restrictive ACL , and as you can see, port 80 is free to run,but it seems to need other ports in order to answer client's request.
Alberto Brivio
Well you can make your inside ACL restrictive by letting your inside users access only services they are supposed to access; I am not against doing that as long as you have a policy stating what is and what is not allowed.
For the outside ACL there is not much you can do other than permitting all access to port 80 of your webserver. The normal security practice is to put such machines in a DMZ in order to limit the impact of a security incident. If you have the option of enabling IOS FW service on your router I will recommend that as it will ease up a lot of things.
