NAT issues? Cant access internet from inside network?
Shawnw4401
I've been puzzled with this issue for a couple of days now. I am stuck on what the issue might be. The issue is that I can ping from my router, G0/0 and G0/1, to the internet. However, from my PC and switch, I cannot ping the Internet. I am pretty sure everything is configured properly, but here's my configuration for the switch and router:
Router 1:
version 15.1
no service pad
service password-encryption
hostname LAN_Router_1
boot-start-marker
boot-end-marker
enable secret 5 ***********************
no aaa new-model
no network-clock-participate slot 3
dot11 syslog
no ip source-route
ip cef
ip domain name MyTestLab.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC105013BA
username ********** privilege 15 secret 5 ***********************
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
interface Loopback0
ip address 192.168.254.1 255.255.255.255
interface GigabitEthernet0/0
ip address dhcp
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.0.1 255.255.255.248
ip flow ingress
ip flow egress
ip nat inside
glbp 100 ip 192.168.0.4
glbp 100 priority 115
glbp 100 preempt
duplex auto
speed auto
media-type rj45
router ospf 5
router-id 192.168.254.1
network 192.168.0.1 0.0.0.0 area 1
network 192.168.254.1 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 10 permit 192.168.94.32 0.0.0.15 log
access-list 10 permit 192.168.17.0 0.0.0.7 log
access-list 10 permit 192.168.52.0 0.0.0.7 log
access-list 10 permit 192.168.0.0 0.0.0.7 log
access-list 10 deny any log
control-plane
mgcp profile default
banner login ^C
W A R N I N G
THIS IS A PRIVATE COMPUTER SYSTEM.
This computer system including all related equipment, network devices
(specifically including Internet access), are provided only for
authorized used.
All computer systems may be monitored for all lawful purposes, including
to ensure that their use is authorized, for management of the system, to
facilitate protection against unauthorized access, and to verify security
procedures, survivability and operational security.
Monitoring includes active attacks by authorized personnel and their
entities to test or verify the security of the system. During monitoring,
information may be examined, recorded, copied and used for authorized
purposes.
All information including personal information, placed on or sent over
this system may be monitored. Uses of this system, authorized or
unauthorized, constitutes consent to monitoring of this system.
Unauthorized use may subject you to criminal prosecution. Evidence of
any such unauthorized use collected during monitoring may be used for
administrative, criminal or other adverse action. Use of this system
constitutes consent to monitoring for these purposes.
^C
line con 0
logging synchronous
login local
line aux 0
line vty 0
login local
transport input ssh
transport output ssh
line vty 1 4
login
transport input all
scheduler allocate 20000 1000
ntp server 198.60.73.8
ntp server 13.85.70.43
event manager applet SaveRunConfig
event timer cron cron-entry "0 0 * * *"
action 1.0 cli command "enable"
action 2.0 cli command "write memory"
Router 2:
version 15.1
hostname LAN_Router_2
boot-start-marker
boot-end-marker
!card type command needed for slot 1
logging monitor warnings
no aaa new-model
clock timezone CST -5 0
dot11 syslog
ip source-route
ip cef
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
voice-card 0
license udi pid CISCO3845-MB sn FOC1411592J
username ********************** secret 5 ***********************
redundancy
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 192.168.254.2 255.255.255.255
ip address dhcp
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
media-type rj45
ip address 192.168.0.2 255.255.255.248
ip flow ingress
ip flow egress
ip nat inside
glbp 100 priority 110
duplex auto
speed auto
media-type rj45
router ospf 5
router-id 192.168.254.2
network 192.168.0.2 0.0.0.0 area 1
network 192.168.254.2 0.0.0.0 area 0
ip default-gateway 192.168.0.1
no ip http server
ip access-list extended SSH
permit tcp host 192.168.52.2 any eq 22 log
permit tcp 192.168.10.0 0.0.0.255 any eq 22 log
permit tcp host 192.168.17.18 any eq 22 log
permit tcp host 192.168.0.1 any eq 22 log
permit tcp host 192.168.0.2 any eq 22 log
permit tcp host 192.168.0.3 any eq 22 log
permit tcp host 192.168.0.5 any eq 22 log
deny
ip any any log
control-plane
banner login ^C
W A R N I N G
authorized used.
purposes.
^C
line con 0
session-timeout 360
exec-timeout 360 0
password 7 *********************
logging synchronous
login local
line aux 0
login
line vty 0 4
access-class SSH in
logging synchronous
login local
transport input ssh
Switch:
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
hostname LAN_Switch
boot-start-marker
boot-end-marker
username ******privilege 15 secret 5 ***************************
no aaa new-model
clock timezone CST -6
switch 1 provision ws-c3750-24ts
system mtu routing 1500
ip routing
ip domain-name MyTestLab.com
spanning-tree mode rapid-pvst
spanning-tree logging
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 192.168.254.5 255.255.255.255
interface FastEthernet1/0/1
switchport access vlan 17
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet1/0/2
switchport access vlan 10
interface FastEthernet1/0/3
switchport access vlan 666
shutdown
interface FastEthernet1/0/4
shutdown
interface FastEthernet1/0/5
shutdown
interface FastEthernet1/0/6
shutdown
interface FastEthernet1/0/7
shutdown
interface FastEthernet1/0/8
shutdown
interface FastEthernet1/0/9
shutdown
interface FastEthernet1/0/10
shutdown
interface FastEthernet1/0/11
shutdown
interface FastEthernet1/0/12
shutdown
interface FastEthernet1/0/13
shutdown
interface FastEthernet1/0/14
shutdown
interface FastEthernet1/0/15
shutdown
interface FastEthernet1/0/16
shutdown
interface FastEthernet1/0/17
shutdown
interface FastEthernet1/0/18
shutdown
interface FastEthernet1/0/19
description ## PC ##
interface FastEthernet1/0/20
description ## X_BOX ##
shutdown
interface FastEthernet1/0/21
switchport access vlan 94
interface FastEthernet1/0/22
switchport access vlan 5
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
shutdown
interface GigabitEthernet1/0/2
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan5
ip address 192.168.0.5 255.255.255.248
interface Vlan10
ip address 192.168.10.2 255.255.255.0
interface Vlan17
ip address 192.168.17.17 255.255.255.248
interface Vlan52
ip address 192.168.52.1 255.255.255.248
interface Vlan94
ip address 192.168.94.33 255.255.255.240
router ospf 5
router-id 192.168.254.5
log-adjacency-changes
network 192.168.0.5 0.0.0.0 area 1
network 192.168.10.2 0.0.0.0 area 2
network 192.168.17.17 0.0.0.0 area 2
network 192.168.52.1 0.0.0.0 area 2
network 192.168.94.33 0.0.0.0 area 2
network 192.168.254.5 0.0.0.0 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.4 permanent
no ip http server
ip access-list extended SSH_IN
deny ip any any log
banner login ^C
W A R N I N G
authorized used.
purposes.
^C
line con 0
session-timeout 60
exec-timeout 60 0
logging synchronous
login local
line vty 0
access-class SSH_IN in
login local
line vty 1 4
login
line vty 5 15
login
event manager environment suspend_ports_config flash:/susp_ports.dat
event manager environment suspend_ports_days 7
event manager directory user policy "flash:/policies/"
event manager session cli username "stw"
event manager policy sl_suspend_ports.tcl
event manager policy tm_suspend_ports.tcl
Well, I totally forgot about the 'log' keyword and NAT:
Does Cisco IOS NAT support ACLs with a "log" keyword?
A. When you configure Cisco IOS NAT for dynamic NAT translation, an ACL is used to identify packets that can be translated. The current NAT architecture does not support ACLs with a "log" keyword.
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/26704-nat-faq-00.html
So your problem is not the wildcard mask, but the 'log' command...
17 Replies 17
I think the problem is with your GLBP configuration. Try to configure host dependent load balancing (do that on the other GLBP router as well):
ip flow ingress
ip flow egress
ip nat inside
glbp 100 preempt
glbp 100 load-balancing host-dependent
duplex auto
speed auto
media-type rj45
Gpauwen,
 Thanks for pointing out the host-dependent for me. I did forget to add it when I was setting up glbp, but unfortunately, that wasn't the issue to this problem. Here was the results:
LAN_Router_2#show run int g0/1
Building configuration...
Current configuration : 280 bytes
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
media-type rj45
end
LAN_Router_2#ping google.com source 192.168.0.2
Translating "google.com"...domain server (8.8.8.8) [OK]
Sending 5, 100-byte ICMP Echos to 24.220.112.151, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/17/20 ms
LAN_Router_2#exit
[Connection to 192.168.0.4 closed by foreign host]
LAN_Switch#ping google.com source vl 5
Translating "google.com"...domain server (8.8.8.8) (8.8.4.4)
% Invalid input detected at '^' marker.
LAN_Switch#show int vl 5
Vlan5 is up, line protocol is up
Hardware is EtherSVI, address is 001a.2f87.b641 (bia 001a.2f87.b641)
Internet address is 192.168.0.5/29
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:00:07, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
131670 packets input, 12246694 bytes, 0 no buffer
Received 0 broadcasts (9930 IP multicasts)
52020 packets output, 5077358 bytes, 0 underruns
0 output errors, 2 interface resets
LAN_Switch#
I am not sure if the syntax is right:
try
LAN_Switch#ping google.com source 192.168.0.5
gpauwen,
I get the same error when typing the IP address into the syntax.
can you do an extended traceroute with 192.168.0.5 as the source ? I am curious to know where the address is being routed...
gpauwen,
Sure, when I did a extended traceroute, here was my result:
LAN_Switch#traceroute
Protocol [ip]:
Target IP address: 8.8.8.8
Source address: 192.168.0.5
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to 8.8.8.8
1 192.168.0.3 0 msec 0 msec 0 msec
2 * !H *
LAN_Switch#
What device is 192.168.0.3 configured on ? It is not one of of the routers or the switch...
gpauwen,
Not really sure why it went to 192.168.0.3, but I'll post it's configurations. It's part of the glbp as well. The router was down when I was posting.
version 15.1
hostname LAN_Router_3
boot-start-marker
boot-end-marker
enable secret ***************
no aaa new-model
dot11 syslog
no ip source-route
ip cef
license udi pid CISCO3845-MB sn FOC1050590C
username ****** privilege 15 secret *****************
redundancy
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 192.168.254.3 255.255.255.255
ip address dhcp
ip flow ingress
ip flow egress
ip nat outside
no ip virtual-reassembly in
duplex full
speed 100
media-type rj45
ip address 192.168.0.3 255.255.255.248
ip flow ingress
ip flow egress
ip nat inside
glbp 100 priority 105
duplex auto
speed auto
media-type rj45
router ospf 5
router-id 192.168.254.3
network 192.168.0.3 0.0.0.0 area 1
network 192.168.254.3 0.0.0.0 area 0
no ip http server
deny ip any any log
control-plane
banner login ^C
W A R N I N G
authorized used.
purposes.
^C
line con 0
session-timeout 180
logging synchronous
login local
line aux 0
line vty 0
session-timeout 180
logging synchronous
login local
transport input ssh
line vty 1 4
session-timeout 180
login
transport input ssh
Some more useful information, maybe? I did a show ip nat translation of the three routers. Here was the finding:
Router 1:
LAN_Router_1#ping google.com source 192.168.0.1
Sending 5, 100-byte ICMP Echos to 24.220.112.153, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/24/36 ms
LAN_Router_1#show ip nat trans
LAN_Router_1#show ip nat translations
Pro Inside global Inside local Outside local Outside global
tcp 24.***.***.***:22 192.168.0.1:22 192.168.0.3:59415 192.168.0.3:59415
Router 2:
Sending 5, 100-byte ICMP Echos to 24.220.112.155, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/18/20 ms
LAN_Router_2#show ip nat trans
icmp 24.***.***.***:0 192.168.0.2:0 24.220.112.155:0 24.220.112.155:0
Router 3:
LAN_Router_3#ping google.com source 192.168.0.3
Sending 5, 100-byte ICMP Echos to 24.220.112.24, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/21/24 ms
LAN_Router_3#show ip nat trans
icmp 96.***.***.***:3 192.168.0.3:3 24.220.112.24:3 24.220.112.24:3
LAN_Router_3#
how is the switch connected to the router, that is, what interfaces on both devices are being used ?
Gpauwen,
The interfaces of how the devices are connected:
Internet <- GigabitEthernet0/0 Router 1: GigabitEthernet0/1 -> Switch FastEthernet1/0/22
Internet <- GigabitEthernet0/0 Router 2: GigabitEthernet0/1 -> Switch FastEthernet1/0/23
Internet <- GigabitEthernet0/0 Router 3: GigabitEthernet0/1 -> Switch FastEthernet1/0/24
Not sure what was really wrong with my access-list, but that seemed to be the problem.
Here's what my access-list looked like:
Here's what I changed it too:
access-list 10 permit 192.168.0.0 0.0.255.255
Can someone elaborate on what the issue is with my previous access-list? Also, if I use the same access-list 10 permit 192.168.0.0 0.0.255.255 with a log and access-list 10 deny any log, I will get the same result of no internet access.
Gpauwen,
I appreciate that little inside note. I never knew that. I could have sworn my ACL always had a deny any log and work. (Apparently not) Thanks for all your help with this issue, it is greatly appreciated and even learned something new. The wonders of troubleshooting.
