NAT issues in load sharing
laoussa07
HI all,
     I have installed a cisco router in load sharing knowing that I have two ADSL links to connect to internet one of them with a fixed IP public address that i want to use to access the internal FTP server using NAT/PAT from the outside, I already try to configure it but I still can't access the FTP server from outside when both links are connected knowing that when i use just the ADSl link with the public fixed IP it's work fine;
     my configuration is as below; please any ideas or any comments it's urgent and I need to fixe this issue ASAP. thanks in advance.
____________________________________________________________________________________________
Router#sh running-config
Building configuration...
Current configuration : 4649 bytes
version 15.2
service password-encryption
hostname XXXXXXXXXXX
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXX
no aaa new-model
ip cef
ip domain name XXXXXXXXXXX
no ipv6 cef
controller VDSL 0/0/0
controller VDSL 0/1/0
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
track 1 interface Dialer0 ip routing
track 2 interface Dialer1 ip routing
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ATM0/0/0
 no ip address
 no atm ilmi-keepalive
 pvc 8/35
  pppoe-client dial-pool-number 1
interface Ethernet0/0/0
 no ip address
 shutdown
interface ATM0/1/0
 no ip address
 pvc 8/35
  pppoe-client dial-pool-number 2
interface Ethernet0/1/0
 no ip address
 shutdown
interface Dialer0
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp chap hostname XXXXXXXXXXXX
 ppp chap password XXXXXXXXXXXX
 ppp pap sent-username XXXXXXXXXXXXX password XXXXXXXXXXXXXXXX
 ppp multilink
interface Dialer1
 mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 2
 dialer-group 2
 ppp multilink
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.2.200 21 interface Dialer0 21
ip nat inside source static udp 192.168.2.200 21 interface Dialer0 21
ip nat inside source static tcp 192.168.2.200 20 interface Dialer0 20
ip nat inside source route-map adsl1 interface Dialer0 overload
ip nat inside source route-map adsl2 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 10 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2
access-list 11 permit 192.168.2.0 0.0.0.255
access-list 12 deny   192.168.2.200
access-list 12 permit 192.168.2.0 0.0.0.255
route-map adsl2 permit 10
 match ip address 12
 match interface Dialer1
route-map adsl1 permit 10
 match ip address 11
 match interface Dialer0
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Best regards,
ip access-list extended MY_FTP_SOURCE
 deny   ip host 192.168.2.200 192.168.0.0 0.0.255.255
 permit tcp host 192.168.2.200 any
 >>>OR ! permit ip host 192.168.2.200 any
route-map PBR_FTP permit 10
 match ip address MY_FTP_SOURCE
 set interface Dialer0 Null0
interface G0/0
 ip policy route-map PBR_FTP
PS: why do you use "dialer-group" per interface and not "dialer persistent"?
Hello, you need to create PBR on inside interface, that would always push your FTP server over Dialer0 interface.
hi Vasilii,
     Could you please send me the command or a procedure on how to apply the PBR on the inside interface,
thank you in advance.
interface G0/0
Thank you very much @Vasilii
