RPS 2300 not backing Router 2921
sankarccie
We have a 2300 RPS with single 1150WAC power supply (C3K-PWR-1150WAC) which is connected to one 2921 Router. But it is not backing the rotuer.
Router 2921 running IOS
c2900-universalk9-mz.SPA.152-2.T1.bin
I am getting the following logs:
*** External Redundant Power Supply is present, but type is unknown or not supported.***
%ENVMON-1-POWER_WARNING: : RPS Online Insertion and Removal is not supported.
Do we required any configuration to be done on Router end.
Note: The RPS is backing 2960 Switch.
Regds,
Sankar V
thiland
Level 3
Level 3
Hi Sankar,
A 2921 ISR G2 router requires both power supplies be populated in the RPS 2300.  Also, there is no hotswap support in the RPS.  For example, if you remove the RPS cable from the 2921 and plug it back in, you will need to reboot the router for it to recognize the RPS unit again.
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/Internal_Modules.html#wp1182874
Table 5-3     RPS 2300 Backup Capabilities
Power Mode
Quantity and Type of RPS 2300 FRU
Quantity 1 C3K-PWR-750WAC
Quantity 2 C3K-PWR-750WAC
Quantity 1 C3K-PWR-1150WAC
Quantity 2
C3K-PWR-1150WAC
2911 in RPS
2921, 2951 in RPS
2911 in POE Boost
2921, 2951 in POE Boost
Table 5-3 shows RPS 2300 backup capabilities when coupled with Cisco 2900 series ISRs.
No configuration is necessary on the router.  You can use "show env rps" on any attached RPS device to check status.
Hi Thiland,
I had rebooted the Router once and now it showing as
External Redundant Power Supply is present and in standby mode.
TVSMISPN-01#sh environment rps
RPS Name: RPS 2300
  State: Standby
  PID: PWR-RPS2300
  Serial#:
  Fan: Good
  Temperature: Green
  RPS Power Supply A: Present
    PID             : C3K-PWR-1150WAC
    Serial#         :
    System Power    : Good
    PoE Power       : Good
    Watts           : 300/850 (System/PoE)
  RPS Power Supply B: Not Present
DCOut  State   Connected  Priority  BackingUp  WillBackup  PortName
     1  Active  No                6  No         Yes         <>
     2  Active  No                6  No         Yes         <>
     3  Active  No                6  No         Yes         <>
     4  Active  No                6  No         Yes         <>
     5  Active  No                6  No         Yes         <>
     6  Standby Yes               6  No         No         Router2921
Hi everyone im on the middle of a messy thing i have 1 C2921-AX/K9 and 1 WS-C2960X-48TS-L connected to a RPS with two power supplies of 750watts but when i connect both and test the redundancy with the RPS unplugged the main power supply both the SW and de Router going off, the question is how many power supplies i need in what combination? 750 and 1100 or both of 1100 watts?
