NAT ISSues
Kaushik Ray
I cannot see any entries on the NAT translations; anyone can advice please? for the .25 ip address but can see for the .1
ip access-list extended POLICYNAT
 permit ip host 172.16.2.25 172.17.37.176 0.0.0.15
 permit ip host 172.16.2.25 172.17.37.192 0.0.0.15
 permit ip host 172.16.2.25 172.17.37.208 0.0.0.15
 permit ip host 172.16.2.1 172.17.37.176 0.0.0.15
interface GigabitEthernet0/0
 ip address 172.28.209.110 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 172.16.2.1 255.255.255.0
 ip nat inside
ip nat pool VPN 172.17.40.97 172.17.40.97 netmask 255.255.255.240
ip nat inside source list POLICYNAT pool VPN
Pro Inside global         Inside local          Outside local         Outside global
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.178:57012   172.17.37.178:57012
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.178:57014   172.17.37.178:57014
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.178:57015   172.17.37.178:57015
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.210:51106   172.17.37.210:51106
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.210:51115   172.17.37.210:51115
tcp 172.17.40.97:443      172.16.2.1:443        172.17.37.210:51129   172.17.37.210:51129
--- 172.17.40.97          172.16.2.1            ---                   ---
Any one knows why the issue is? tried a ping / traceroute from the .25 and it shows this
traceroute -s 172.16.2.25 172.17.37.210
traceroute to 172.17.37.210 (172.17.37.210), 30 hops max, 60 byte packets
 1  172.16.2.1 (172.16.2.1)  1.733 ms  1.803 ms  1.908 ms
 2  172.16.2.1 (172.16.2.1)  2.036 ms !H * *
Anyone can tell me where i may be going wrong!
Robert Falconer
Try adding the overload command to your entry:
ip nat inside source list POLICYNAT pool VPN overload
