NAT - local users should have access to local server through outside (global) IP
snikonenko
We have a router 2911 and couple global (internet) IPs. One IP address we use for our website, and the second IP we use for users. So we use NAT to translate local IPs to outside (nat overload) for users, and static NAT translation for website. Our website accessible from outside, but LAN users can't get access to server using outside IP.
Test stand config:
interface GigabitEthernet0/0
 description LAN | Local Network
 ip address 2.2.2.254 255.255.255.0
 no ip proxy-arp
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description WAN
 ip address 1.1.1.254 255.255.255.0
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description DMZ
 ip address 5.5.5.254 255.255.255.0
 no ip proxy-arp
 ip nat inside
 duplex auto
 speed auto
ip nat inside source route-map nat interface GigabitEthernet0/1 overload
ip nat inside source static tcp 5.5.5.5 80 1.1.1.5 80 extendable
ip route 0.0.0.0 0.0.0.0 1.1.1.100
!1.1.1.100 ISP DG
!172.172.0.0 - vpn ip pool
access-list 110 deny   ip 2.2.2.0 0.0.0.255 172.172.0.0 0.0.255.255
access-list 110 permit ip 2.2.2.0 0.0.0.255 any
route-map nat permit 10
 match ip address 110
 match interface GigabitEthernet0/1
The question is - is it possible to make users get access to local website using global IP - 1.1.1.5?
Any suggestions?
snikonenko
The problem not solved, but I found that if ip address on outside nat interface (in my config 1.1.1.254) different from IP pool that I use for translation for 7.7.7.5 for local 5.5.5.5 and 7.7.7.1 for any local 2.2.2.0 network (but in my config 1.1.1.5 and overload 1.1.1.254) and ISP has route to this pool, users from local network can get access to local server useing outside global IP.
Any comments?
And one more - I can't debug ISPs router and I don't really understand how it works)
