Upgrading 1841 router for ssh
wilsonb431
I am trying to upgrade my Cisco 1841 router for use with SSH. I am wondering what are the requirements needed, and which version should I install on the router?
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 15:40 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 21 minutes
System image file is "flash:c1841-ipbase-mz.150-1.M4.bin"
Last reload type: Normal Reload
Cisco 1841 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FTX145002U9
2 FastEthernet interfaces
4 Low-speed serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
63808K bytes of ATA CompactFlash (Read/Write)
License Info:
 --More--
License UDI:
Device#  PID SN
*0    CISCO1841             FTX145002U9
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You'll need a crypto image.
Do you know which IOS I need to use?
You need to download a K9 image like this one:
c1841-ipbasek9-mz.150-1.M10.bin
http://tools.cisco.com/search/results/display?url=http%3a%2f%2fsoftware.cisco.com%2fportal%2fpub%2fdownload%2fportal%2fselect.html%3fi%3d!s%26imageGuId%3d7375B5134CACAB15E14D39A3139F85FC49593D90&pos=1&query=c1841-ipbasek9-mz.150-1.M10.bin
Or you can move to 15.1(4)M10 which is the latest for this platform.
[+5] to Paulo and Joseph.
Hi Wilson,
you can also run Feature Navigator tool to find the image using Search by Platform option[1841 in your case] , then , Major release/Release/Feature Set
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
regds,
aman
