NAT many-to-one
alberto-pesce
Hi all,
 I would like implement a configuration based on (Cisco 2800, ios 12.4(13r)T) in order to have clients inside that connect a server outside using a single outside IP address.
Best Regards
6 Replies 6
Richard Burts
What you describe is an almost classic depiction of Port Address Translation which is the type of Network Address Translation that translates multiple inside addresses to a single outside address, typically using the outside interface address with overload.
Rick
Rick
 do you think that I have to implement also some access-list? My scope it is to forge client's request to the server as a Unique IP address (due to the restriction on server 172.16.0.250)
Best Regards
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip address 172.16.0.254 255.255.255.0
ip nat outside
ip nat inside source static 192.168.0.1 172.16.0.8
ip nat outside source static 172.16.0.250 192.168.0.8
I am a bit puzzled by your response. In your original post you were quite clear that you need translation for many to one. But in your response you are showing examples of static one to one translation.
If you are going to do Port Address Translation then it is likely that you would need an access list to identify the traffic that is to be translated.
Rick
Rick
Sorry for the puzzle.
My intent it is to find a workaround for Server that accept only one client connection per each. I'm trying to forge multiple request as coming form single IP address, as reported in the scenario attached on my first post.
It is now more clear? Could you suggest something?
Thank in advance
Best Regards
If you want requests coming from multiple sources to look like a single source then you need your translation to be dynamic and not static.
Rick
Rick
Ok, with the configuration below it is working :-)
how can I create a pool with single IP address instead of 4?
ip nat inside
ip nat outside
ip nat pool NAT-pool 172.16.0.2 172.16.0.5 prefix-length 29
ip nat inside source list 100 pool NAT-pool
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
