NAT on 1 Physical Interface
nino.sehovic
Hi everyone...
I need some help please.
I have a site with a router and all of its ports are already taken except one.
The thing is i need 2 interfaces for a customer that wants a seperate connection to the internet with NAT. Ofcourse they ill have their own
IP address and own Internal Ip Address.
The external ip address would be 77.77.77.1 (for example) and the inside 10.204.0.0 255.255.0.0
The problem is that i have only 1 interface can i somehow NAT over subinterfaces or Virtual interface?
As far as i have seen on the documentation it is not possible,but perhaps one of u guys has an idea????
Thanks in advance...
30 Replies 30
With which command do you get this error?
ping 8.8.8.8 source 77.77.77.1
it means IP address of 77.77.77.1 is not set on the any interface.
Show ip int brief
If you do not see 77.77.77.1, create it
int loopback 100
ip address 77.77.77.1 255.255.255.255
I know Masoud but u said earlier i should not put this IP on any interface...which was awkward for me...If i set it to loopback its ok but since i dont have any interfaces free I dont know where to set this IP Adddress,thats the main problem.I have onyl 1 interface free on which i configured the network between my router and customer router...
I understand. I just want to test that IP. I want to make sure that IP works.
Create that interface with IP of 77.77.77.1. Ping and then remove it.
no interface loopback 100.
If you are sure your new IP works, skip that test.
Masoud
masoud yes the ip works like i posted earlier if i set it to loopback its np it works...
OK :)
access-list 50 was not in your config. add it and then
It is just for test. I want to check your NAT works.
Interface G0/0 is already connected to a switch so
Int g0/0
Ip address 10.204.0.1 255.255.0.0
Ip nat inside
Connect a pc to your switch (VLAN1)
PC IP and gateway
10.204.0.2
255.255.0.0
10.204.0.1
Another way to test
interface GigabitEthernet0/0.70
encapsulation dot1Q 70
ip nat inside
Create vlan 70 on switch
connect PC to a switch port in vlan 70
configure IP on PC and test.
I can not connect it to Gig0/0 since its connected to a switch already and the production is going on :) I cant touch anything right now besides the gig0/1.
Thats is the problem :) There are also no free ports on the switch and i do not have access to the switch since its on a remote side. I may try the subinterface gig0/0.50 or so and then ask somebody to try it...I was thinking of doing it that way masoud but its really complicated i guess in the end i will have to go and order a new FA Module for my router and then I will have no problems :P Anyways thank you a lot for your help.
OK.
So the problem is not NAT. The problem is port density.
Gig 0/1 has IP address. It is in production also? How are you going to connect your customer to to G0/1 which is already in production?
Is Digel your new customer?
interface GigabitEthernet0/1
description DIGEL-LAN
ip address 192.168.50.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
The only free PORT is PORT gig0/1 which is not in production, my initial question was if there are no more free slots,if there is a possibility to do nat inside and outside on only 1 port in this case the port Gig0/1.
Check the attachement again pls Masoud :D
Just listen to me :D.
The configuration will be the same as configuration you chose as a correct answer.
I gave another configuration related to G0/0 because I saw your configuration and thought g0/1 is in production. How would I know DIGEL is your new customer?
I am giving you the final configuration one more time with 192.168.50.1
no touch on Gi0/0
interface G0/1
Des conneted-to-customer
IP address 192.168.50.1 255.255.255.0
IP nat inside
access-list 50 permit 10.204.0.0 0.0.255.255
ip nat pool Public-IP 77.77.77.1 77.77.77.1 prefix 24
ip nat inside source list 50 pool Public-IP overload
Ip route 10.204.0.0 255.255.0.0 192.168.50.2
ON your customer router
IP route 0.0.0.0 0.0.0.0 192.168.50.2
The configuration above is your final configuration.
The configuration below is just test for you to make sure nat works
I want to simulate your laptop as your customer
no touch on Gi0/0
interface G0/1
Des conneted-to-a laptop
IP address 10.204.0.1 255.255.0.0
IP nat inside
Connect a laptop to port G0/1.
Give  laptop IP and gateway
 IP address 10.204.0.2 255.255.0.0
Gateway  10.204.0.1
and set DNS
and browse the web.
Test the second configuration with your laptop to make sure NAT works then connect your customer with the first configuration.
No touch on Gi0/0 :)
Thank you Masoud I will try it tommorow :)
Trouble shooting.
Ping 10.204.0.1 from your laptop. ( you should get replies)
ping 8.8.8.8 ( you should get replies)
Show access-list 50  ( you should see hit)
show ip nat translation | include 77.77.77.1  (should have entries after test by your laptop)
Give me your feedback.
Masoud
Adding to my previous comment.
Int g0/0
Ip nat inside
PC IP and gateway
10.204.0.2
255.255.0.0
10.204.0.1
Another way to test
ip nat inside
connect PC to a port in vlan 70
Masoud
Where did you get did error? With ping?
