NAT on 1942 router
BHconsultants88
Hi everyone
I've pasted the configuration from a Cisco 1941 below and sure I haven't missed anything but wanted a second (expert) opinion
Everything seems to be working fine except that traffic from 185.2 network is not reaching the natted LAN IP of 1.1.1.97. Outbound, it works absolutely fine, however not inbound. The traceroute fails at 2.2.2.2 (outside interface of this router) so I'm leaning towards an outside NAT problem.
Could you somebody take a look, as it's really baffling me.
Thank you
Current configuration : 4598 bytes
! Last configuration change at 22:20:37 UTC Sat Feb 18 2017 by admin
version 15.5
service password-encryption
hostname BOATHOUSE
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
ethernet lmi ce
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FGL204221LZ
username admin privilege 15 password 7
redundancy
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Outside
ip address 2.2.2.2 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description House LAN
ip address 1.1.1.1 255.255.255.0 secondary
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool DOCK 10.10.10.20 10.10.10.254 netmask 255.255.255.0
ip nat inside source list 10 pool DOCK
ip nat inside source static 1.1.1.97 10.10.10.42
ip route 0.0.0.0 0.0.0.0 2.2.2.1
ip route 172.6.0.0 255.255.0.0 1.1.1.254
ip tacacs source-interface Loopback0
ip access-list standard Hub
permit 185.2.0.0 0.0.255.255
permit 10.100.0.0 0.0.255.255
permit 10.101.0.0 0.0.0.255
permit 45.50.0.0 0.0.31.255
ip access-list standard customer-nets-out
permit 10.10.10.0 0.0.0.255
snmp-server community public RO
tacacs server 10.200.68.90
tacacs server 10.200.68.91
access-list 10 remark NAT Pool for Dockstation
access-list 10 permit 172.6.0.0 0.0.255.255
access-list 10 permit 1.1.1.0 0.0.0.255
access-list 61 permit 10.100.66.77
access-list 61 permit 10.100.66.145
access-list 61 permit 10.100.66.133
access-list 66 deny any
control-plane
privilege exec level 0 traceroute
privilege exec level 0 ping
privilege exec level 0 terminal monitor
privilege exec level 0 show running-config
privilege exec level 0 show configuration
privilege exec level 0 clear ip accounting
banner login ^CCC
* Use of this network is restricted to authorized users. *
* User activity is monitored and recorded by system *
* personnel. Anyone using this network expressly consents *
* to such monitoring and recording. BE ADVISED, if possible *
* criminal activity is detected, system records, along with *
* certain personal information, may be provided to law *
* enforcement officials. *
BOAT ^C
line con 0
exec-timeout 15 0
privilege level 15
password 7
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 15 0
privilege level 15
transport input all
line vty 5 15
exec-timeout 15 0
privilege level 15
transport input none
scheduler allocate 20000 1000
end
You do not have to remove it. I just wanted to say that having 10.10 is not mandatory..
After adding the deny statement, clear IP nat translation * and delete and reconfigure your stating NAT, The reason is if there is dynamic NAT, you router does not add the static NAT in the NAT table.
Masoud
8 Replies 8
I doubt even your outbound NAT is working. You are trying to translate to inside addresses, that is, you are trying to translate 1.1.1.0/24 to 10.10.10.0/24, which is the inside address range.
For your NAT to work, the outside interface GigabitEthernet0/0 must have an IP address from the 10.10.10.0/24 address range.
The outside router (connected to GigabitEthernet0/0) is 2.2.2.1. This router has a static route of:
10.10.10.0 255.255.255.0 via 2.2.2.2
Would this not be sufficient or would I need to specify an internal IP on outside interface as well?
In addition to the above, please see entry of IP Nat trans
tcp 10.10.10.42:58326  1.1.1.97:58326  185.2.88.42:80 185.2.88.42:80
Doesn't this prove that outbound traffic is being natted correctly?
What are you trying to accomplish ? Both 10.10.10.0/24 and 2.2.2.0 are private addresses, so NAT between those address ranges is not needed. Is 185.2.88.42 a valid public address ? Your next hop router with IP address 2.2.2.1 is the one connected to the Internet on the outside ?? If so, that is where you need to configure the NAT.
Your configuration says,
1- If a packet arrives with source of 10.10.10.0/24, forward it  to 2.2.2.1 with no change.
2- if a packet comes with source of 1.1.1.0/24, forward it  to 2.2.2.1 and change the source address to 10.10.10.20-254
3- if a packet comes with source of 172.6.0.0/16 , forward it  to 2.2.2.1 and change the source address to 10.10.10.20-254
4- if a packet comes with destination of 10.10.10.42 from outside, change the destination to 1.1.1.97
If you intend to do these, your configuration is correct, otherwise you need to change.
You do not need to configure 10.10.10.* on you router. You can completely remove it as long as you have return route on the next router.
There is only one issue. You are confusing your router. It may cause problem.
You have static NAT:  ip nat inside source static 1.1.1.97 10.10.10.42
and 1.1.1.97 is in your access-list : access-list 10 permit 1.1.1.0 0.0.0.255
You need to remove 1.1.1.97 from the access-list
access-list 10 deny   1.1.1.97
Hope it helps,
Masoud
Masoud, thank you so much. That's exactly what my configuration is saying.
The problem is with point 4. Traffic from outside is not being natted to inside 1.1.1.97
Your suggestion
"You do not need to configure 10.10.10.* on you router. You can completely remove it as long as you have return route on the next router."
I will try this now. I will also add the deny statement for 1.1.1.97 on the ACL
Thanks for your help and I will feedback shortly.
Masoud
Hi Masoud, thanks very much for your help with this one. It worked a treat. Would you mind giving me some pointers on: https://supportforums.cisco.com/discussion/13248851/asa-vpn-query
For some reason, I'm unable to get connectivity
