NAT on ASR 920
Hi Guys,
Currently i'm using Cisco ASR 920 as Internet Gateway, I've got problem when i configure nat, those feature not available.
Could you give information, should i ugrade IOS version ?
below IOS version existing :
Cisco IOS XE Software, Version 03.16.01a.S - Extended Support Release
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(3)S1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 04-Nov-15 14:37 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
R1RO-ASR920-A uptime is 16 hours, 29 minutes
Uptime for this control processor is 16 hours, 31 minutes
System returned to ROM by reload at 20:20:21 Jakarta Wed Apr 20 2016
System image file is "bootflash:/asr920-universalk9_npe.03.16.01a.S.155-3.S1a-ext.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroipaccess
License Type: Permanent
Next reload license Level: metroipaccess
cisco ASR-920-24TZ-M (Freescale P2020) processor (revision 1.2 GHz) with 909923K/6147K bytes of memory.
Processor board ID CAT1951V0ZM
24 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
3910656K bytes of USB flash at usb0:.
Rohmat
0 Replies 0
