NAT on cisco ASA according to server availability
jakubholly
Hi, simple scenario. PC want to get to server.
ASA check by IP SLA availability route to Server A and to Server B. Is there any option how to translate NAT IP on ASA to local IP of server according availability? (Server A a Server B are on different private address)
example Server A  is reachable
client goes to Public IP ->on ASA NAT to private IP to subnet Server A
example Server B is reachable
client goes to Public IP -> on ASA NAT to private IP to subnet Server B
any suggestion? thanks a lot
what interface is  IP 213.71.143.136 configured on ?
The only object (and NAT you have) refers to:
object network Public
host 213.71.142.140
Either way, the EEM script (two actually) would look something like this:
event manager applet PRIMARY_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "object network server-BA-int"
action 4.0 cli command "no nat (inside,outside) static Public service tcp 9989 9989"
action 5.0 cli command "exit"
action 6.0 cli command "object network server-BB-int"
action 7.0 cli command "nat (inside,outside) static Public service tcp 9989 9989"
action 8.0 cli command "end"
event manager applet PRIMARY_UP
event track 1 state up
action 3.0 cli command "object network server-BB-int"
action 6.0 cli command "object network server-BA-int"
you could combine the IP SLA with an EEM script. The EEM script adds/removes the necessary NAT translation based on the state of the IP SLA.
Post the config of the ASA.
Hi Georg,
thanks for your reply. It should listen on public  213.71.143.136:9989 and translate it to private IP according to actually available 1 of 2 servers. SLA trak the end-address. Maybe EEM could help.
hostname ciscoasa
names
interface Ethernet0/0
nameif outside
security-level 100
ip address 10.152.222.17 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 0
ip address 10.152.222.11 255.255.255.240
host 10.153.193.189
host 10.152.193.189
host 213.71.142.140
route inside 10.152.193.189 255.255.255.255 10.152.222.1 1 track 1
route inside 10.153.193.189 255.255.255.255 10.152.222.1 254
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
sla monitor 123
type echo protocol ipIcmpEcho 10.152.193.189 interface inside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
telnet timeout 5
ssh timeout 5
ciscoasa(config)#
host 213.71.142.140
There is no interface with this IP, but the communication (with DA 213.71.142.140) come from interface outside. ASA special, that you can translate IP  without  having it in some interface
