1100 ISR throughput
adamgibs7
Level 6
Level 6
Dears,
It is confusing to understand what is the default throughput of ISR 1000 series router, i have been through different links and on every link the throughput differs , i hope somebody can help me to understand the default throughput.
Also i would like to know what does alphabet " V" stands for in VPERF and what does alphabet " H" stands for in HSEC, hence these are mentioned as performance license.
link 1 is datasheet.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html#CiscoIOSSoftwarelicensingandpackaging
link 2
https://www.cisco.com/c/en/us/products/routers/1000-series-integrated-services-routers-isr/compare-model.html
Link 3:
https://www.cisco.com/c/dam/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/q-and-a-c67-739639.pdf
balaji.bandi
here what i have learned -
IPSec Performance (VPERF)  - for performance of IPSEC youi need to add exatra
if you like HSEC you need to buy an additional license those do not come as default
BB
Joseph W. Doherty
First, crypto requires a separate add on license, which appears to usually limit crypto performance to 50 Mbps, within these series of routers.  For higher crypto performance, you'll need another license, either the VPERF or HSEC licenses.  The former, VPERF, will boost crypto performance up to a higher limit, determined by the actual model, while the latter, HSEC, removes the crypto logical performance limit.
Crypto, with the HSEC license, or non-crypto traffic performance will vary based on the actual router model.  There's no logical limit.
As to the actual meaning of VPERF and HSEC, doing a quick check, I didn't find either defined, but I would guest it's something like virtual performance for VPERF and high security (performance) for HSEC.
