nat on loopback
n.bokhar1
Level 3
Level 3
hi i have this topology
linux: 10.2.2.100
win  : 10.2.2.50
i also have two loopback interfaces
loop1 : 1.1.1.1 255.255.255.255
loop2 : 2.2.2.2 255.255.255.255
both interfaces have ip nat outside under config
and i have these nats as well
ip nat inside source static 10.2.2.50 interface loop 1
ip nat inside source static 10.2.2.100 interface loop 2
now i want to connect to my window machine from Linux on 1.1.1.1 ip address
but i cant
how can i do that ?
15 Replies 15
Julio E. Moisa
The switches cannot run NAT, it should be configured on the router, so your configuration should be:
ROUTER
interface loopback 1
ip address 1.1.1.1 255.255.255.255
interface loopback 2
ip address 2.2.2.2 255.255.255.255
interface g0/0
description >>INTERNAL NETWORK<<
ip nat inside
interface g0/1
description >>INTERNET or EXTERNAL NETWORK<<
ip nat outside
ip nat inside source static 10.2.2.50 <interface loop 1 IP address>
ip nat inside source static 10.2.2.100 <interface loop 2 IP address>
ip route 0.0.0.0 0.0.0.0 <public or next hop IP>
** Now if it is used to translate to Internet, the IP addresses used with the loopback should be public IP addresses provided by an ISP.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
it is configured on the router
switch is just there for basic connectivity
Thank you, thas is correct.
As sir Julio confirmed config is okay, just give it a try with IP address instead than interface(s).
ip nat inside source static 10.2.2.50 1.1.1.1
ip nat inside source static 10.2.2.100 2.2.2.2
Thank you.
Kindest regards,
Uzzi
Kindest regards,
Uzair
CCENT, CCNA (R&S), CCNP (R&S).
Thank you Muhammad, you are right, it was fixed
thank you guys for your replies but that didn't work any other solutions?
Could you please share your configuration, switch and router
Thank you
SWitch:
interface GigabitEthernet0/0
switchport mode access
media-type rj45
negotiation auto
interface GigabitEthernet0/1
switchport access vlan 2
media-type rj45
negotiation auto
interface Vlan1
ip address 10.1.1.1 255.255.255.0
shutdown
interface Vlan2
ip address 10.2.2.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.1.2
Router :
interface Loopback1
ip nat outside
ip virtual-reassembly in
interface Loopback2
ip nat outside
ip address 10.1.1.2 255.255.255.0
ip nat inside
duplex auto
speed auto
media-type rj45
ip address 172.18.1.1 255.255.255.0
ip nat outside
duplex auto
speed auto
media-type rj45
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/1 overload
ip nat inside source static 10.2.2.50 interface Loopback2
ip nat inside source static 10.2.2.100 1.1.1.1
ip access-list standard NAT
permit any
The loopback address must be known through the next hop, for example:
SWITCH ----- ROUTER (cient) ---- ROUTER (ISP)
ROUTER (client)
* IP nat outside is not required under the loopback interfaces, it can be removed
* You need to add a default route: 0.0.0.0 0.0.0.0 <next hop IP - ISP router interface IP address>
 something like:
 ip route 0.0.0.0 0.0.0.0 172.18.1.2
The IPS's router must know the following IP addresses:
1.1.1.1/32
2.2.2.2/32
so you could create:
ip route 1.1.1.1 255.255.255.255 <next-hop IP - Client's router Interface IP>
ip route 2.2.2.2 255.255.255.255 <next-hop IP - Client's router Interface IP>
Hope it is useful
Hello
Not sure if you wanted the loopbacks of the rrtr to be natted to a static 172.18.1 x address however in the example below i have applied such nat.
You also have some mis-configuration on the switch regards the vlans and connection to the rtr.
see example below:
Switch:
conf t
ip routing
interface Vlan1
no shutdown
no ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip route 0.0.0.0 0.0.0.0 vlan 1 10.1.1.2
Router :
conf t
ip route 10.2.2.0 255.255.255.0 gig0/0 10.1.1.1
ip route 0.0.0.0 0.0.0.0 gig0/1 172.18.1.x  < isp lan facing ip address)
interface Loopback1
ip nat inside
interface Loopback2
ip nat inside
ip nat inside
ip nat outside
no ip nat inside source static 10.2.2.50 interface Loopback2
no ip nat inside source static 10.2.2.100 1.1.1.1
no ip access-list standard NAT
permit ip 10.1.1.0 0.0.0.255 any
permit ip 10.2.2.0 0.0.0.255 any
ip nat source static 1.1.1.1 172.18.1.x
ip nat source static 2.2.2.2 172.18.1.x
res
Paul
Kind Regards
Paul
n.bokhar1
Level 3
Level 3
thanks to all you guys for your replies but they are not what i look for and also don't work
this is my network i have no other stuff
i want to connect to server 2 from server 1 but with 1.1.1.1 ip address which is set on my routers loopback it is fully working when i connect to the server from the internet but when i do it from server 1 it fails and when i telnet to 1.1.1.1 from server 1 the router cli opens up witch i don't want
so what can i do to :
telnet from server 1 to 1.1.1.1 and my server 2 cli opens not the router.
i also tried a bunch of other ios versions and other routers they are all do the same
Hello
thrn you will need to nat hairpin to achieve that
https://supportforums.cisco.com/t5/wan-routing-and-switching/nat-reflection-nat-hairpin-on-a-cisco-router/td-p/3302833
 https://supportforums.cisco.com/t5/wan-routing-and-switching/nat-hairpinning/td-p/2475807
Res
paul
Kind Regards
Paul
