nat on Network
david foley
Could some one help me please with NAT.
I have a C licence (195.100.190.0/24)
A ISP WAN that connects to the Customer site uses network Address 199.1.1.36/30
& Loopback 126.0.0.1/8
i have
on ISP
ISP#show run
Building configuration...
Current configuration : 956 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip domain-lookup
interface Loopback0
  ip address 126.0.0.1 255.0.0.0
interface FastEthernet0/0
  no ip address
  duplex auto
  speed auto
  shutdown
interface FastEthernet0/1
  no ip address
  duplex auto
  speed auto
  shutdown
interface Serial0/0/0
  ip address 199.1.1.37 255.255.255.252
  clock rate 64000
interface Serial0/0/1
  no ip address
  shutdown
interface Vlan1
  no ip address
  shutdown
ip classless
ip route 195.199.190.0 255.255.255.0 Serial0/0/0
ip route 195.100.190.0 255.255.255.0 Serial0/0/0
banner motd ^C
ONLY STAFF WITH PASS KEY ^C
line con 0
  exec-timeout 0 0
  password cisco
  logging synchronous
  login
line vty 0 4
  password cisco
  login
line vty 5 15
  password cisco
  login
end
ISP#copy run start
Destination filename [startup-config]?
[OK]
ISP#
ISP#
ISP#
ISP#
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to up
ISP#
ISP#
ISP#
ISP#show run
version 12.4
hostname ISP
no ip domain-lookup
interface Loopback0
  no ip address
  duplex auto
  speed auto
  shutdown
  no ip address
  duplex auto
  speed auto
  shutdown
  clock rate 64000
  no ip address
  shutdown
interface Vlan1
  no ip address
  shutdown
ip classless
banner motd ^C
line con 0
  exec-timeout 0 0
  password cisco
  logging synchronous
  login
line vty 0 4
  password cisco
  login
line vty 5 15
  password cisco
  login
end
on R1
%SYS-5-CONFIG_I: Configured from console by console
R1#show run
Current configuration : 1303 bytes
version 12.4
hostname R1
username R1 password 0 cisco
username R2 password 0 cisco
  no ip address
  duplex auto
  speed auto
  shutdown
  no ip address
  duplex auto
  speed auto
  shutdown
  ip address 199.1.1.38 255.255.255.252
  ip nat inside
  ip address 172.190.0.14 255.255.255.252
  ip nat inside
interface Serial0/1/0
  ip address 172.190.0.1 255.255.255.252
  encapsulation ppp
  ppp authentication chap
  ip nat inside
interface Serial0/1/1
  ip address 172.190.0.5 255.255.255.252
  ip nat inside
  clock rate 64000
interface Vlan1
  no ip address
  shutdown
router ospf 1
  log-adjacency-changes
  network 172.190.0.0 0.0.0.3 area 0
  network 172.190.0.4 0.0.0.3 area 0
  network 172.190.0.12 0.0.0.3 area 0
  default-information originate
ip nat pool MY-NAT-POOL 195.100.190.241 195.100.190.246 netmask 255.255.255.248
ip nat inside source list NAT pool MY-NAT-POOL
ip nat inside source static 172.190.0.254 195.1.1.254
ip classless
ip route 0.0.0.0 0.0.0.0 199.1.1.37
line con 0
line vty 0 4
  login
line vty 5 15
  login
end
i can i allow the rest of the Network Ping ISP, R1 can ping the Loopback 0 address but want the rest of the network to ping it.
Dear ,
no need to set the ACL on the interface like " ip access-group NAT IN" .This is needed only when you wanted to block or allow certain things in your network .
I was saying to create an access-list for the nat. You have defined the nat statement as given below ,in which your source-list name is NAT
So just define your souce list NAT as given below . You have given the name NAT for your access-list and may be you are confused due to this . Just add an ACL as given below . Add all your local network in the access-list named NAT.
ip access-list extended NAT
permit ip 172.90.0.0 0.0.0.255 any
6 Replies 6
sujinair
Hi David,
Looking at the configs on R1 I'm a bit confused, all interfaces are configured as "ip nat inside", to NAT the traffic outside Serial0/0/0 you need to configure "ip nat outside" on that interface.
Sujit
Haris P
Level 4
Level 4
Dear ,
It seems that S0/0/0 is your outside interface . if so yyou hae to put ip nat outside on that interface as gien below
  ip nat outside
Secondly you didnt define the ACL or source list NAT,you can define as given below .Add all of your network in that NAT access-list
haris
Missed the ACL part, thanks for pointing it out Haris :-)
Sujit
i set up the Nat, and change S0/0/0 to Nat outside,
With the Access-list i set the on S0/0/0 as
still not able to ping
Dear ,
Thanks man,
The ACL done the trick..
